Results 1 to 9 of 9
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Valve cover stud came off
    After doing my TB, VC gasket and thermostat I ended up with 2 leaks. A coolant leak on the top radiator hose area and one right on top of the camshaft chain tensioner. I opened up the VC today to add some more RTV on that side and while I was tightening the nuts to put it back together I noticed one nut/stud kept spinning. I wobbled it and it was pretty loose so I took it out:
    Took the VC off all over again to try and see if it would go in but the threads are stripped, you can actually see in the pic that some threads came out with the stud.
    What are my possible options to fix this??
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Dec 05 2007
    Helicoil
    Jan 07 2013
    Helicoil
    I couldn't find any locally so I got one from Amazon with next day shipping, thanks.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by RDA990 View Post
    I'm assuming you got a kit with the special tap and installation tool.. https://www.amazon.com/Helicoil-5546...FFRZBQDN7Q02G0
    Jan 07 2013
    Quote Originally Posted by Kevin C View Post
    Yea that's the same exact kit I bought.
    Dec 05 2007
    You could have picked up the cheap OEM brand at any auto parts store. This is also a standard for any hardware store like True Value, Home Depot, Ace Hardware, and quite possibly can also be found in Walmart (not validated along with hardware stores, but it is a standard repair item and not just automobile specific. it's thread repair, like a tap and die). Anyways, very common issue and very common solution. Avoid reoccurrence by adjusting your feeler method or use factory torque specs.
    Mar 28 2015
    That's a great price for the real thing. I have had my kits Helicoil kits for more than 35 years and they still work great (and I'm still not as old as Old Guy) . I probable paid more for them... Competition is a good thing.
    Jan 07 2013
    I looked online at local stores and they all had them for shipping, none in store. NAPA has some Helicoils in store but none were the M6 size I need. UPS should be here any minute now with the one I ordered yesterday.
    Jan 07 2013
    The Helicoil worked perfectly fine, took less than 10min to do. Valve cover is sealed fine with no oil leaks. I had to cover the whole area so none of the metal shavings made its way to the engine.
    Also bought a torque wrench so this doesn't happen ever again .
