Originally Posted by
torquewrench
Is it possible to reach the crankshaft pulley bolt from the bottom of the vehicle, or does it require moving parts to get access? Don't need to remove any bolts. My vehicle is a repair shop and they want to charge 2-3 hours labor to see if the engine will manually turn over freely. It's 45 minutes away, so I can't check it out myself.
The only parts that would have to be removed to access the pulley for something like this is the belly pan. Like was said, there are 8 bolts on the girl. Not sure if some kind of strap wrench would provide enough grip to turn her over manually, but I would imagine it could be done. Not sure what this 2-3 hours of labor there is. To put the car in service mode takes ~20 minutes from on the ground and using jack stands, less with a lift. I've timed it. Any more than and hour and they're charging you for them to learn imho.
