Installed a new slave cylinder, but when I went to bleed it the plastic hex head bleed screw rounded the first time I tightened it down. I think it needs a few more pump-and-bleeds, but the more I tried to get it off the rounder it became. It's now basically a circle. Access is none to minimal. I tried to get some channel locks on it, which I can, but there's no room to twist it. Bolt off sockets did not work since it's plastic and not metal. I have another bleed screw from a broken slave cylinder I can use, but I can't get the current one off.
Anyone have any suggestions that don't involve removing the downpipe and/or dropping the subframe? Pretty much everything is bolted back up to the car, and I'd like to remove as little as possible, obviously. I dropped the axle at the transmission for some more access, but that's about it.
Thanks for any suggestions. I know this is a common problem, and I think I just don't have the right tool to get at that area. Wondering what other people have done to manipulate a rounded off plastic bleed nut.
