Originally Posted by
S4tech2
Not trying to be a smart ass but I'm well below 10k on my setup with srm k24 hybrids. Even though I'm not even to the 500 hp mark yet if you know how to do the work yourself and understand how to make things work, a low budget can be maintained. Now I'm not an expert on putting a lot of money into one and achieving high hp, but I know you don't have to spend a fortune to achieve it.
Now I know of your multiple builds and you are a very smart guy, but please throw some specs at us, how much did you source you engine for and what not. Reading the few vr6 build threads they do not offer much specifics. It's mainly "a vr6" with some "custom stuff" to bolt it in.
Define "well below" and what you started with and where you are now and what you omitted please. This isn't my first rodeo
At the BARE minimum this is what I see what needs to happen for a full transformation of a bone stock S4... that is just hard parts and ZERO labor added, zero costs of tools that you might need, etc.
From them:
turbos, DV's, DP, Exhaust, SMIC, bipipes, MAF/CAI = $3900
Injectors + MAF sensor (HPX) + tune - $1000
Clutch + FW - $1500
Fuel pump - $150
Fuel filter - $22
Wideband - $200
TBB - $50
Air filter - $50
Suspension - $1500+
Control Arms - $500
Brakes (refresh stock with uprated discs and pads) - $500
Wheels and/or tires - $1000+
Boost gauge $100
Fluids (Oil, Coolant, Filter) - $150
Timing belt, WP, gaskets/seals - $500
Electric fan kit - $250
Engine mounts - $400
Tranny mounts - $300
Spark plugs - $50
Coil pack conversion (since it's roughly half the price of buying new OEM coils, boots + ICMS) - $480
Grand total of $12,602.00 Plus tax (if applicable) + shipping costs. Not to mention all the other hidden costs when dealing with an older car like this that pop up when you start pulling things apart. And I'm sure I'm forgetting stuff!
Sure you can have a clapped out upgraded turbo S4 for less then that, but not much less and the thing will be junk... and you can argue that you can nickel and dime here and there... but you still won't be much cheaper and you're dealing with inferior parts, maybe even used parts... who knows. The rabbit hole can only go deeper when it comes to modding.
So what do we have here so far is just over $12k for basic parts list for a ~460awhp S4, wanna hit close to or over 500awhp? You'll need to add at the minimum a methanol kit ($600+).
The point is, people either don't really count what they've actually had to put into their cars or they like to gloss over the details. Building any car (correctly) isn't cheap, even if you have the means to do it yourself.
Imagine now you step up to a Tial turbo kit instead?
