Dyno is a Dynapack (connects to wheel hubs), and ambient air temp was about 82 degrees.
Relevant mods at time of dyno:
- 2001 A4 1.8TQM, 126k miles and stock engine (except upgraded rods)
- FrankenTurbo F21 kit (non-mixed flow, purchased June 2014)
- Motoza tuned with switchable maps, running E85 currently
- Bosch EV14 750cc injectors, seeing ~75% max IDC. Stock 4bar FPR.
- Deatschwerks DW200 fuel pump
- engine has I.E. connecting rods, and tune accommodates them
- 3" MAF housing
- 3bar MAP sensor
- Treadstone TR18T FMIC, 2.5" cold-side and 2" hot-side piping
- 034 3" HFC
- 2.5" custom cat-back exhaust with Magnaflow mufflers
- B7 RS4 clutch kit with ECS Tuning RA4 flywheel
- the car's tune is conservative enough that it doesn't see more than 1.5 degrees of knock on any cylinder at WOT
- car hits 25psi, but tapers to prevent MAF readings from going much above 240 g/s to improve turbo life
As you see, max torque shown is 1270 ft-lbs; this is the direct reading from the wheels. To get engine torque, you divide that 1270 by the drivetrain reduction (4.108:1), and that's how 309 AWTQ is calculated.
The lesser dashed lines are from a prior dyno 2.5 years ago. That was the old FT F4H turbo, and on 91 octane, and with a clutch that I believe was slipping.
