Results 1 to 16 of 16
    Established Member Two Rings torquewrench's Avatar
    Jan 26 2009
    WA
    Stumped - S4 Turns off while driving
    After having both my catalytic converters replaced, I went to pick up the vehicle. I haven't had it in over a month, so I was elated...for about a 1/2 mile when the car just shut off. No warning lights, nothing. It's as if someone reached over and turned off the key. Still had all lights, etc. Attempting to restart it, the engine would begin to turn over for a fraction of second then stop. Below is a video of the no start condition. Almost like a battery was too low to crank. Jump starting failed. Towed back to shop.
    Shop inspected to see if they missed something during cat install. Scanned codes:
    P154500 - Throttle valve control system Malfunction
    P157900- Throttle valve control module, J338, Adaptation not initiated
    P10A700 - Adaptation regulating flap for intake air soiled
    Replaced battery with new one since the old was original. Inspected throttle body, and it moves freely. Removed supercharger belt to make sure supercharger would turn freely. The car eventually just decided to start, but it would stall immediately every time right after startup. Adapted throttle body, and the car did start and run seemingly ok. Test drove it around nearby for 10 minutes or so to make sure it would be ok. Left for the 45 mile drive home. 1/2 way home it died on the freeway. Same thing all over again: car would turn over slowly and not start (almost dead battery like symptoms) After waiting for 30 minutes or so, it did start but ran rough. This time a warning came up about the oil pressure being low! Arg. Towed to another shop as I was hoping to get the car closer to my home.
    Scanned again:
    P154500 - Throttle valve controller malfunction.
    P10A400 - Intake Air regulating Flap - Mechanical Malfunction
    P164D00 - Oil Pressure switch for reduced oil pressure
    Towed car back to shop that did cats. They are investigating it currently. Any ideas?
    Stock 2011 Audi S4, ~68K miles.
    https://www.youtube.com/embed/RWBRt4mBzxg
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    I don't know if that could help but maybe more info on Year? Mileage? Mods?
    Murdered B8.5 S4
    Build Thread
    Jan 26 2009
    WA
    Quote Originally Posted by silverf0x View Post
    Added to post, thanks.
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    Maybe I am reading it wrong, but was it running fine prior to replacing the catalytic converters?
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Mar 01 2006
    Kitchener, ON
    I believe there is a valve / sensor that is under the supercharger that needs replacing. I looked through my paperwork and I guess they didn't record the exact code but it was a $20 part but the labor involved was high because it involved removing the supercharger.
    I had the same symptoms, and the mechanic cleared the codes. It happened again after, so I cleared it again with VAG on a Friday night. Come Monday the car was driving fine all weekend, gave it a few days and about a year later it never happened again.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Jan 26 2009
    WA
    Quote Originally Posted by withENEMYin View Post
    No, it had a really bad misfire due to the fully blocked cat. It was running so rough it would barely stay running. Right after the cats were replaced, it ran perfect. Until it didn't run at all.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    The throttle body code is for throttle position sensor wire harness not being properly connected to the throttle body or there's a short in it. I would not take the car anywhere else (even tho I would want to) because you're going to have to pay a new shop to fix the first shops mistakes. Good luck brotha
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jan 26 2009
    WA
    Quote Originally Posted by RudyH View Post
    RudyH- Thank you so much for the info. No one has been able to give any insight, so I appreciate the help!
    Dec 30 2015
    Sacramento, Ca
    Also the low oil pressure is probably from the rough hunting idle, but hopefully you have a dipstick to atleast verify capacity.
    Jan 26 2009
    WA
    Quote Originally Posted by BlownOne View Post
    Thank you sir!
    Mar 09 2015
    Harrisonburg, Va
    Any updates on this issue?
    Sent from my SM-G930V using Tapatalk
    Jan 26 2009
    WA
    After months, the problem was fixed simply by replacing the engine. No one knows what was specifically wrong with the engine other than it took an abnormal amount of torque to manually turn the engine. After repair, everything was perfect, however there is no way I was taking a chance of something else going wrong. So, I sold it before I lost my mind. I'm driving a newer Honda CRV. 0-60 in 10 minutes or so. It's painful.
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    Quote Originally Posted by torquewrench View Post
    Painful but safe now. I would have done the same if I went through all of that trouble. Thinking of selling mine because of the headaches I've had.
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
    Mar 09 2015
    Harrisonburg, Va
    Ouch, yeah.... My issue isn't exactly the same as yours, hopefully mine won't won't come to that.
    May 17 2012
    Houston, TX
    Wow new engine? Under warranty?
    Jun 11 2014
    Ny
    my car shut off today as I as putting e85 while pumping the gas. it took a few cranks to start back up. Im not sure what it could be, Il scan it once I get home and see what codes it gives.
