Hey guys, I've got a problem that's left me scratching my head
My Audi has been having an issue with cold starts the last month or two. I turn the key to the on position, let the fuel pump prime. Try to start it and she's just crank no start. I'll turn the key off then back to on and try again and she fires right up. No problem. Its like this every cold start in the morning or cold evenings. When it's warm out or the cars warm there's no issue. I've already replaced the things I suspected to be the issue. Cars got a new high flow fuel pump. New fuel filter. New 2.0t coil packs. New spark plugs. New cam position sensor. And I replaced the fuel pump relay switch inside the dash. The MAF is the only thing I haven't replaced yet but I did remove it and do the DIY alcohol cleaning trick. The only way I can get it to avoid the cold start issue in the morning is to unplug the MAF, start it (she fires right up) then plug the MAF back in before it throws a code. Does anyone have any other ideas? I'm at a loss and hate to just keep throwing money at this.t hanks for any help.
