Results 1 to 22 of 22
    Aug 19 2013
    minnesota
    Don't buy the same TIP
    Two years ago I installed the same call turbo inlet pipe. After doing so I had to continuously retighten it on the compressor housing of the ko4 turbo. What an annoying piece of s***. I would like to point out that where the turbo inlet pipe attaches to the compressor housing is bulbous. This of course meaning that the surface that the band clamp you will need to use to attach it to the turbo is not flat or symmetrical. So if you attempt to clamp it down with a hose clamp it will want to move. Also it did not stand up to the test of time very well, it has become softer than you think it should. On the same call the section that goes over the turbo compressor housing is very short as well. This short run also adds to the difficulty in attaching this thing properly.
    I replaced the samco with a forge. The forge had a longer section to attach to the turbo which was not bulbous and was symmetrical. Which made it very easy to attach to the compressor housing. This has fixed a low boost code I've been getting off and on for two years.
    The next day
    https://youtu.be/2V5b7pVIMzo
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 19 2013
    minnesota
    Quote Originally Posted by jacobsen View Post
    The next day
    Can someone rename my title for me. I tried to edit it but it's not an option. It should say samco not same.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I'll just leave this here for you: Clicky click®
    Aug 19 2013
    minnesota
    Haha
    Dec 28 2006
    Western Maryland
    You make an interesting observation. When i installed my Forge TIP I ended up cutting around 1/2"→3/4"" off of the connection to the turbo inlet. The extended length caused the TIP to press hard against the back of the headlight and headlight mounting plate.
    I suspect your problem with the TIP popping off has more to do with your wide "T" clamp than the length of the hose. The K03 turbo inlet flange is pretty short and when you use a wide clamp more of the clamp is on the outside of the flange than the inside of the flange and consequently it pops off. I went with the OEM clamp and problem solved.
    Even when I went with the FT 3" TIP I had the same problem and again going to the OEM narrower clamp solved the problem. You can use the wide clamp on the turbo outlet but not the turbo inlet.
    Apr 17 2016
    kc
    Enlighten me why an aftermarket tip is better than a factory one. I aint got no k04 or frankenturbo so perhaps its a moot point on an almost stock car.
    Aug 19 2013
    minnesota
    I was worried that the new Forge was going to do exactly what you say. But it's several inches away from the back of the head light area. Perhaps they made a modification to the design you had. Your observation about the hose clamp is pretty accurate with exception. I tried 3 different kinds clamps. I begin to suspect that I was getting back pressure from the R1 diverter valve having failed. Eventually I realized that the design of the samco was the reason it was backing off. I really didn't want to jump to that conclusion prematurely. But in the end giving the samco every opportunity and credit because I didn't want to spend money on another part. Switching to the forge solved the issue instantly.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by hightime80 View Post
    For a stock or stage 1 tune it's pretty much a moot point.
    Aug 19 2013
    minnesota
    The turbo inlet pipe is always under vacuum when the motor is running. With the part that is literally living under vacuum constantly it's important to have a stiff structure so that any time you apply throttle and the air increases pressure inside the structure it doesn't collapse under the sucking pull of the turbo. Yes obviously for a stage one it's not really worth the money. This one cost 144 bucks at ECS. The more boost you make with your turbo the stiffer the intake piping should be. Some kits are metal.
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    your headlight switch has alopecia
    Black 04 Audi A4 1.8t
    APR Stage 2+, Koni FSD/Eibach, OEM USP Wheels
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Aug 19 2013
    minnesota
    Quote Originally Posted by teg2audi View Post
    Lol it has character
    May 18 2015
    Uckfield
    I never regret getting forge silicone tips, they really are worth the extra ££$$
    Sent from my XT1572 using Tapatalk
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Sigh
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    < $4, treat yourself. If you want one with "auto" though your going to have to splurge at $5.
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    You beat me to it! Though I was going to suggest this route.
    http://www.ebay.com/itm/HEADLIGHT-FO...BWQVEV&vxp=mtr
    *EDIT* Then I didn't read the whole thread and the person above me suggested the EXACT one. I guess I'm just late to the game.
    Aug 17 2015
    Evansville, IN
    PS, I have an APR, and while I've never had any problems with anything coming loose, it does push against the inside lower tab of the headlight pretty hard. Hard enough that it's kind of a pain to get the headlight seated right if you have to take it out for anything.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Use hairspray and t-bolt clamps.
    Problem solved.
    I still lulz when i see people using cheap shit worm clamps instead of t-bolt.
    Audi Club Bay Area
    Apr 17 2016
    kc
    Quote Originally Posted by Wet0willy01 View Post
    Sigh
    Kids now a days does not know grammer haha.
    I do it on purpose I really do know better Willy😝
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Furly View Post
    Problem solved.
    I went from "cheap shit worm clamps" to T-bolt, then to higher quality worm clamps... the kind with rolled edges, smooth bore. Because they're less narrow than T-bolt they often allow things to seal better.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Aug 19 2013
    minnesota
    I tried them all, don't buy the samco. Trust me on this one.
    Dec 19 2013
    I have a samco on my TB side and running 26psi on a big turbo and it has never popped off.
    Audi Club Bay Area
    Aug 19 2013
    minnesota
    Throttle body side? Me too but their tip for k04 is worthless
