Results 1 to 4 of 4
    Established Member Two Rings 02A4_quattro's Avatar
    Jul 03 2016
    Tuned & lifted Ram 2500 6.7
    New Hampshire
    1.8t big turbo outlet hose
    Hey big turbo guys! I searched and can't find anything on here about what guys with big turbos and custom FMICs do about the outlet hose directly off the cold side of the turbo. I'm talking about the hose that has the branch for the DV and connects the cold side outlet to the intercooler hard pipe. I can't find any aftermarket options whatsoever. My stock one is all twisted up to accommodate the fact that my turbo outlet is at a different angle than the stock position of straight up and down, and an adapter to go from 2 inch at the turbo to my 2 1/2 inch intercooler pipe. I'd really like a reinforced one, but can't find one anywhere
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Once you go custom, everything is going to be custom. There are places that can make you custom silicone lines from a pattern, but pricing really depends on what you are having done and how complex it is.
    Jul 03 2016
    New Hampshire
    Quote Originally Posted by MoparFreak69 View Post
    Ok thanks moparfreak69, that's what I was figuring but wanted to double check if anything was available off the shelf that I hadn't found
    Dec 05 2007
    You can rig up your own concoction from cheap ebay parts.
