Results 1 to 4 of 4
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Mixing pulley upgrade and tunes Can you buy one shops pulley and use a different tune
    So bare with me I'm new to b8 chassis supercharged v6 but not new to audi's. But I've been trying to research into it but it seems as tho there's quite a bit of pulley upgrades for our cars now. But is it acceptable to mix different pulleys and tunes? I.e. Apr or forge pulley with a giac tune, awe pulley with an Apr , etc. Is there really any error to it seeing a few people have done it but I can't find definite info on if its legit or not. Thought about trying to make some stuff work being some pulleys are smaller and cheaper like the cts turbo pulley being the smallest but also the cheapest . Wana know if I could use said pulley with like a giac or Apr or EPL etc tune and what are the possible outcomes
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Both GIAC and APR will not release their Stage II files without their own Pulley and it's serial number. CTS Pulley is good for like an EPL tune or Chipwerke Pro Stage II. Will they work, yes, but again, unless you obtain the serial number code from someone who's never used it, you won't be able to use just any pulley with GIAC and APR.
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jun 20 2015
    NC
    All the pullies will work with all tunes. The main issue is like said above, the serial numbers.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    yes, it's locked into proprietary tune files. You could get a forge pulley file from GIAC, but the pump file is apparently less aggressive at 17-18* of timing versus the normal AWE pulley 22-23*.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
