This is my checklist.
Helmet
Blanket (To lay tools/spare/ect on and to cover up while I am running)
Trash bags (To empty absolutely everything out of the car right before tech, Keeps things organized and I go back through after I get home to ensure what I need and dont need in the car)
Tire pressure gauge
Typical tools
Before I leave I do a pre check.
1. Grab the wheels and push/pull on them very hard till the car shakes around. Any clunking means I wont be able to run and need to replace the bearings.
2. I grab the battery and shake it. If it moves at all, come up with a mounting system so it doesnt.
3. Make sure the positive battery terminal cant touch metal. z
4. Push on clutch pedal for appropriate pressure
5. Push on brake medal for appropriate pressure.
6. Air tires up to proper deg. If I dont have a rear sway bar I add 5lbs to the rear tire to enduce neutral rotation.
Sounds like you had a good time. Driving in the rain is difficult, your ABS is your friend. Being as smooth as can be is really the best here. Dont bother with left foot braking, Unless your running a huge turbo its not going to help with your times at all and will be very difficult to learn.
You should however be threshold braking quite a bit. This helps with rotation of your heavy body mass and keeps you smooth. Brake a little bit late and into the turn in. With the car being front heavy you want to rotate that mass to the front while your doing tight turns so the rear end can follow the front better and you get more tire contact patch for that initial and mid corner turn. As you get closer to the apex and have shed the appropriate amount of speed off you let off the brake completely and apply throttle. In a rear or fwd car you apply throttle as steering correction, but in an awd car you apply throttle as early as you can make the proper rotation as the car will both push and pull you around the rest of the corner..
Remember smooth is fast, but use the AWD advantage mid corner as often as you can.
