Results 1 to 11 of 11
Thread: Winter storage
    May 12 2016
    S4 2012 6MT
    Montreal, Canada
    Winter storage
    Hey guys,
    Due to multiple reasons, I have to store my s4 for about 4 months and I need your help to get my car ready.
    Ive read multiple topics on the internet and everyone seems to say different things.
    I know the classics:
    - unplug battery
    - put on Jack stands
    - put a car cover
    What about the fuel and other fluids?
    Anything else I should consider?
    Thanks for your help!
    Sent from my Nexus 5 using Audizine mobile app
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Marine stabil should be added to fuel tank to keep gas fresh.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Oct 10 2012
    Zionsville and Saint John IN
    I just plug my battery to my charger and forget about it. To me, four months isn't long for a modern day car to sit.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Established Member Two Rings rpalmer's Avatar
    Nov 16 2014
    VW GTI, BMW K1600GTL, and the S4
    Winchester, MA
    Stabil and top off the tank.
    Air the tires up an extra 5-6 pounds.
    -RP
    2012 S4 / Monsoon Grey / 6MT / APR Stage 1 / ECS Tuning dipstick
    Established Member Two Rings MUM3's Avatar
    Sep 06 2016
    2004 Land Rover Disco II : 2018 Q7 Prestige : 2008 VW Jetta SE : 2009 Audi A4
    Springfield, Mo
    Winter storage
    I parked my M3 every winter for the past 8 years. I bought some tire saver ramps, made sure the tank was full with Stabil added, and walked away. I probably should have disconnected the battery, but didn't mess with it. The storage shed didn't have power so there was nothing to plug a trickle into. She always fired up at the end of the winter, and if there was a nice day before spring, I could pull her out and go for a ride.
    2017 S7 P+ Glacier White Metallic | Arras Red Individual | Stock (for now)
    2014 S4 P+ | Monsoon Grey | Black/Silver Nappa Leather | 6MT | Sport Diff | B&O | APR Stage 2 - Single Pulley | APR Carbon Intake | Milltek Non-Resonated Exhaust | Eurocode Sways F/R - Sold
    2005 ///M3 Convertible - Sold
    May 12 2016
    S4 2012 6MT
    Montreal, Canada
    Awesome thanks for the advices guys!
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    i do not do full tanks of gas in my stored vehicles, and or toys.
    reason being: I still put stabil/seafoam in but when you do finally need to drive or use whatever you are storing you are better off at that point putting fresh gas from a pump into the tank instead of having a full tank of old gas. just my 2 pennies
    but ive never had any issues at all, with 1/4-1/2 tank of gas with additives and then topping off with freshies...
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Jul 31 2014
    Mpls, Mn.
    oh and one more thing: i put stabil/seafoam in and then drive and idle for a bit to get it moving through the lines/pump etc.
    all anecdotal stuff, but i find something works i stick to it!
    Jun 29 2015
    I seen no point in stabilizing fuel. I have stored fuel in a non-temperature controlled shed for over 6 month through a northeast winter and have never had it go bad. I believe modern fuel is less likely to go bad, especially when stored to not be overly exposed to air like old open container style gas cans. Modern fuel systems may not gas out and therefore the unused space in the tank will be gas which effectively prevents spoilage from air exposure.
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    Here's what I'll tell you since I was in the same boat as you. Except, my car is put away during the winter (South Dakota) because that's where I'm stationed and I'm currently deployed. The car is going to be sitting for about 7-ish months.
    All of this was done because I don't trust anyone to take the car out and drive it once a week. Especially since I'm not stationed back in California where I can have a family member drive it every once in a while. I put the car away for storage and did all of this because I knew that once the car was parked, the next time it would drive is when I get back.
    1. Top off your tank. You don't want your tank to be half filled and have condensation build up because of the moisture and humidity. I had a lot of trouble finding out the right answer, but this is what I came down to.
    2. Change your oil. Granted, four months isn't a very long time, but you don't want to have old oil sitting around in the car. Especially if you're not running it. Just change it a week in advance or so and you'll be fine.
    3. Battery Tender. This will help keep your battery fresh and charged. You can hook it up to the car, or disconnect the battery and place it somewhere safe too. Definitely would recommend.
    4. Tire Ramps. I think the set I got are called FlatStoppers on amazon. They help prevent flat spots if the car isn't moving around. Just overfill the tires by a few PSI and you'll be okay. Also would recommend.
    5. Fuel Stabilizer. Entirely up to you, but I'm stationed in a cold area, the stabilizer will help.
    6. Detail. You definitely want to do this. Especially if you're planning on putting a car cover on. Car covers do more damage than good if your car isn't clean. After you completely clean the car, throw some dryer sheets on the inside of the vehicle, it'll help keep rats and other insects out. Maybe get a mint scent air freshener too. Put socks or rags in the mufflers, you don't want something living in there for warmth. Same goes for an intake if you have an after market intake.
    I'm thinking you're putting the car away in a garage? I did leave some mouse traps laying around under the car, and moth balls in the corners of the garage. It'll smell, but it'll help.
    I don't think I'm missing anything, but if I am, someone please chime in. Hopefully this helps you out!
    On a side note, I did change out my coolant, you don't have to, but I said why not since everything else was changed lol.
    EDIT: DO NOT leave your car on jack stands. Yeah back in the day people used to do it all the time because they didn't want flat spots on their tires, but we have the technology and equipment today to prevent that. You don't want to leave your suspension unloaded and not in the neutral position for 4 months. You'll come back to other issues you wish you didn't have.
    May 12 2016
    S4 2012 6MT
    Montreal, Canada
    I changed the oil 2000 miles ago and the car will be stored in a tempered area (old factory reorganized to a car storage) I think I have all I need at this point.
    Thanks everyone and @USAF_Danny be safe and thank you for your service!
