In the history of all the cars I've owned, this one will go down as the car with the never-ending fuel system problems. Obviously, I've already been through the cam follower and HPFP failure which fortunately occurred 3000 miles before the extended 120k warranty ran out. I also replaced the electrical lift pump shortly afterwards and opted for the slightly cheaper Siemens VDO version. Still haunted with codes for fuel I changed both high and low pressure sensors, the FPR valve and N80 until I finally discovered that a contaminated camshaft sensor was to blame.
With only 40,000 miles on the new electrical pump, I'm getting the 310B code and occasional stuttering, usually under light load. I ran VCDS and the duty cycle on the pump is around 75-85% at idle. Older logs from my first pump failure show a similar figure with the post-replacement duty below 50% on the new pump at idle. I changed the LP pressure sensor as I had one lying around and then did the fuel filter, which was last changed with the previous pump replacement. To no avail, the pump is still running at high duty. I've just ordered a new pump but this time I opted for the genuine Audi part as suggested in this post from Jef at Ross-Tech...
http://forums.ross-tech.com/showthre...r-Audi-A4-2-0T
I've also read a number of other articles suggesting that non-Audi pumps can prove problematic or short lived. If my experience is anything to go by, I seem to be another case where this is true.
