Results 1 to 13 of 13
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    lowering problems... please help
    Hi
    Just installed lowering links for S6; however, now the back end is stuck at monster truck mode...
    shop has no idea what is causing this!
    Has anyone run into this, or have any idea what to do about it?
    thanks
    Sep 10 2015
    VA
    Quote Originally Posted by HamidsVikes View Post
    Hi
    thanks
    Weird. What amount of drop in MM did they do on both? Did they possibly damage the sensors when removing or installing the links? What brand of links?
    Nov 27 2012
    Houston/Texas
    Quote Originally Posted by Barritia View Post
    Check and make sure the tire change mode isn't enabled.
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Jan 10 2008
    Vancouver, BC
    One of the pieces was damaged during install... but they fixed it...!
    The rear seams to be stuck on tire change mode.!
    8mm was the distance for the link set up!
    Front is sitting low...
    So frustrating!!
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Find another shop. Sounds like they don't know what they are doing. The lowering links are very sensitive and it sounds like they have adjusted them in the wrong direction (it works backwards). I can't imagine how they fixed that broken ball joint and you can't just buy the arm that's broken. Might also be the problem...
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Sep 10 2015
    VA
    So frustrating!!
    I'm Curious how they fixed it. That would require a new part. And as the other poster says the links work in reverse so if they made the links shorter then the car will go higher. They have the front correct so I doubt that's the issue.
    Nov 27 2012
    Houston/Texas
    They probably just plastic soldered the ball back on it. I would look at getting a new part to prevent you going down the road one day and having it snap off.
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    There is something very wrong there. That looks way higher than even tire change mode.
    Probable guess would be that the "fix" they did on the broken ball did not take that one or both links are simply not connected and the system is not getting any info and thus gone full extension.
    I don't think you could even get that high with links installed and adjusted all the way out
    Sep 28 2009
    suburb
    You don't fix that broken joint. You replace it. A proper shop would tell you they will replace it for you and the "fix" is very temp and that you should not drive on it honestly until it is replaced.
    Imagine what can happen if you are driving and suddenly rear pops up like that.
    Jan 10 2008
    Vancouver, BC
    Repair work
    Sep 10 2015
    VA
    Is it still not fixed? Have they tried putting the stock ones back in the rear to see what happens? If it still rides high after doing that then they must have twisted the sensor arm so much that it damaged the sensor.
    Established Member Two Rings jagata's Avatar
    Apr 15 2014
    So. Cal
    That repair is satisfactory, really imo it's better than a new part.
    May 17 2016
    Seal Beach, CA
    check MMI to see if you are in towing mode...
