1994 Audi S4
I picked this car up about 8 months ago but I am now purchasing another car so I have a total of 4 vehicles. Needless to say, I need to part with one and I've chosen this one. This is a clean car that is capable of being a daily driver so I will NOT part it out. It has a ton of recent maintenance (within the last 2 years) and runs strong. Mechanically this car is solid and the interior is in very good shape. The exterior could use some love as it appears to have had a cheap respray at least once. I will list the good and bad below. Asking $3700 obo.
The Good:
Ecu with stage 2 tune and 4bar GM map sensor upgrade (no check engine lights!)
Tap stage 2 wastegate spring
New pcv pancake valve and pcv*valve*
New oil sending unit
New cam position sensor
New AGM Battery
New fuel filter
Recently Cleaned Maf
New Beru ignition coil
NGK Vpower plugs
Rotella T6 oil change with Mann filter
New K&N air filter
New gauge overlays
Bosch boost gauge*
New Contiental Serp Belt
Timing belt job
•continental Tbelt
•behr thermostat
•INA tensioner and idler*
•pentafrost coolant
• graf waterpump
New uro parts coolant reservior
Mishimoto silicone boost hoses
Aftermarket DV (could be forge or xspower?)*
New Front pads and Rotors
Eibach lowering springs w/ bilstein shocks
After market grill and debagged emblems (previous owner)
Momo shift knob
6disc cd player (factory)
All power options are in working order including seat heaters
Oe fuchs wheels painted rally white with red Audi emblems
2 new tires on rear
Rear diff lock working
Replaced broker washer fluid jug with a used one in great shape.
Replaced brake fluid with dot 4 pentosin.
Replaced Trans fluid and Rear diff fluid when I purchased the car
The bad:
Windshield is cracked. (Passes inspection & is $200 installed to replace)
AC recently stopped but I am including a brand new compressor (just needs installed)
Car needs bodywork on roof. But it is structurally sound with no leaks
Odometer stopped working at 168k so estimated mileage is 180-195k other gauges function properly (I'm including a working gauge cluster that is not yet installed)
Nice sounding aftermarket exhaust but there is a slight rattle at low speed
