Results 1 to 7 of 7
    Feb 19 2010
    Menomonee Falls WI
    Help needed Identifing a part!!! Slightly urgent!
    Set out to change the oil today, done is many many times on this car no problem. Get done and start the car up and it runs like garbage, flashing CEL, I shut it off and check to see if I knocked something loose and sure enough I did. There is a vacuum sensor of some kind right at the back of the intake manifold that came undone. It doesn't seem to want to snap back together but I didn't force it too hard. I see no clip that fell that's suppose to hold it together. What is this part and how do I get it to stay together and not fall open? Do I need a new one?
    Sorry I don't why the pictures are rotated and upside down
    Jan 24 2010
    Paramus,NJ USA
    Suction jet pump.Very common failure as they are only glued together.You can try to reglue.I normally just replace.
    Ziddy Autowerks
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You can superglue it as a temporary repair but consider replacing it with the new design that has a screwed on cap rather than a glued on cap. When you go to glue it take a close look at the cone side. There is a small rib that has to align between two ribs forming a slot on the receiving body. As soon as you take a look it will be very apparent.
    Dec 28 2008
    old guy, where is the screwed on cap design for sale? None of the ones I see specify they are screw on.
    Apr 17 2016
    kc
    Dorman 911-400
    Autozone has them. Got one on my car. Works perfectly.
    http://m.autozone.com/engine-managem...ve/434017_0_0/
    Dec 28 2006
    Western Maryland
    Senior Member Three Rings Arnie91's Avatar
    Oct 28 2015
    London
    Replace it. I did a temp fix on mine after a mechanic broke it when changing the rear coolant flange. I lost all brakes going 40MPH in traffic building up. I had to mount the verge and pull the handbrake (which did nothing).
    http://www.ebay.com/itm/Suction-Jet-...hXObLU&vxp=mtr
