Results 1 to 40 of 49
    Senior Member Two Rings TurboNate's Avatar
    May 15 2015
    El Cajon/CA/San Diego
    Crazy Engine Shuddering
    I'm having an issue with my car, and I'm not 100% sure to what it is. When accelerating, the engine starts to shudder very rigorously. This started once I tuned to APR stage 1. It was once in a while, now it's every time. After countless hours of searching I came to the idea that it could be my coil packs/spark plugs. I'm not 100% sure because everyone with the coil packs being the issue had a check engine light (which I don't). I've ordered both coils and plugs and are waiting for them to arrive but I'm not sure if that's even the issue. Anyone have some insight? (I do not have a VCDS to scan)
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Maybe an engine mount failing?
    May 15 2015
    Quote Originally Posted by pierreb View Post
    What are the symptoms of a failing engine mount?
    AKA: NathanMansoor
    Dec 01 2011
    Quote Originally Posted by TurboNate View Post
    pretty much what you're experiencing. the engine vibrates more as the mount is prob failing and giving less cushion, you feel it more during acceleration.
    IG @theshawon
    May 15 2015
    It's not vibrating. Like the engine is stuttering. Cuts off power and the car shakes
    AKA: NathanMansoor
    Dec 01 2011
    oh i see, if it's cutting off power and shuddering then it's prob not mounts then. seems like it could be the coils or plugs, they won't always throw a code that happens if there's a misfire, but who knows, maybe the coil isn't giving power properly but not really misfiring. are you able to put it into a stock tune mode and see if it still does the same thing? might want to check with APR too since their tune seemed to do it.
    IG @theshawon
    May 15 2015
    Quote Originally Posted by Liquid Smoke View Post
    I have tried but arin suggested different gas, which didn't do much. I'm going to change the coils and plugs and see if that does anything. If not. I'm lost..
    AKA: NathanMansoor
    Jun 23 2013
    PacNW
    Does it do this when you rev it in park/N?
    When you say accelerating, what RPM? Does it happen just as the boost is really coming on?
    May 15 2015
    Quote Originally Posted by skis4hire View Post
    Yes it does when I'm reving. And yes it does when there is boost. I'm not sure as to what RPM
    AKA: NathanMansoor
    Veteran Member Three Rings Comp4k's Avatar
    Aug 10 2009
    Carlsbad, CA
    I had this EXACT problem, turns out it was a failing PCV, PureMS diagnosed it by doing some vacuum testing. Here's the part that they replaced:
    https://www.ecstuning.com/b-genuine-...v/06h103495ac/
    Also, another symptom is fluctuating RPMs while idle. Basically the valve isn't staying closed under boost and is causing excessive crankcase vacuum. I'm at 75k miles- also needed 3 of my motor mounts replaced too :(.
    May 15 2015
    Quote Originally Posted by Comp4k View Post
    If the coils/plugs don't fix it I'm definitely going to try this! Thank you so much. (Coils arrive tomorrow, installing Tuesday morning)
    AKA: NathanMansoor
    Aug 10 2009
    Carlsbad, CA
    Yep, I too thought it was sparks at first but no misfire codes. Also, my car is Stage 1 APR too.
    May 15 2015
    Damn there goes another $150
    AKA: NathanMansoor
    May 15 2015
    **UPDATE**
    CEL turned on today. Scanned it with OBDII and got P0303 (misfire in cylinder 3). The CEL was flashing for about 5 seconds then went way.
    AKA: NathanMansoor
    May 15 2015
    **UPDATE 2**
    Went to clear codes and Carista stats's that my voltage is too low... alternator was just changed, is the battery bad now?
    AKA: NathanMansoor
    May 15 2015
    Just got out of class to check the battery level. It's now dropped to 80%... was at 90% before class. Is this normal Or am I in trouble
    AKA: NathanMansoor
    Aug 10 2009
    Carlsbad, CA
    **UPDATE 2**
    How old is your battery? I had to get mine changed at the 5 year mark.
    May 15 2015
    No clue but I got it tested at my mechanics shop and he said battery is fine
    AKA: NathanMansoor
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    When I was stage one id occasionally get that stutter around 2800-3000 under high load(full boost) going up a hill or something when the trans hasnt downshifted, Too me it felt like either a missfire or detonation. B8 6zf tip. I never had a cel throw.
    It still very rarely does it with stage 2 but I usually try to avoid that kind of scenario.
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
    May 15 2015
    Quote Originally Posted by KompressorLOgic View Post
    That's how it was when I first got the tune! But it's progressively gotten worse and worse now it's really bad.
    AKA: NathanMansoor
    May 15 2015
    Changed the coils and plugs. No more studdering/shuddering!! How ever over night the battery life dropped to 70%.. I had checked it with my mechanic and he said it's good. I checked with my tool this morning and it says it's good. Anything that could be draining power? Could it have been the bad coils?
    AKA: NathanMansoor
    May 15 2015
    **UPDATE**
    Went to go start up the car and now it has very rough idling, and misfiring in cylinder 4. Tried switching coils around and spark plugs and it's only in 4, getting code P0304. Removed PCV valve to check if it's bad, the flap is fine. It's not stuck open. Any ideas?
    AKA: NathanMansoor
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    Injectors? Not an quick job, but you can swap the injectors around to see if the misfire follows the injector.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    May 15 2015
    Quote Originally Posted by Townending View Post
    Injectors were replaced 2k miles ago after carbon cleaning
    AKA: NathanMansoor
    2020 A4 allroad
    NH
    What year car and mileage? Could be your timing is screwed up from bad tensioner or something in the head is damaged like a guide.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    All we are doing here without VCDS is basically shooting in the dark, or playing throw money at the problem....
    You need a proper scan to diagnose what is happening to get a starting point for us.
    2016 S3
    Instagram- @Thisisastickup
    May 24 2007
    PA
    I would try the PCV. I had a P0303 and a new PCV fixed the problem. $85 for the part from the dealer.
    Not sure what you mean by PCV flap, mine had a tear in the rubber diaphragm.
    May 15 2015
    Quote Originally Posted by b6Hate4 View Post
    Quote Originally Posted by s4baby View Post
    I went to the dealership and purchased new coils from them, went home and it was great. Started up like a champ. Did some 2nd and 3rd gear pulls and it was amazing. Best I've felt it since tuning it. Go home and turn off car then want to take my mom to go shopping and it takes a good 3 seconds to crank. Usually 1 second to turn over. I get a CEL, then scanned it. I got about 3 codes. (See attachments). Reset codes and drove it. RPM's were fluttering around 2k-2.5k. Went away and now it's fine? I'm getting annoyed with all the problems
    AKA: NathanMansoor
    Oct 27 2010
    Norwood, MA.
    P0303 is just a cyl. 3 misfire.
    The fact that he is getting a code for multiple, and 4 makes me think it is a fuel pressure issue, since there is a code for that, and since the 4th injector is the last to get fed, and will be the first to suffer fuel pressure/ volume issues.
    I'd bet a dozen donuts that you have a clogged fuel filter, failing sending unit (pump in the tank) or a failing HPFP. All signs point to it.
    2016 S3
    Established Member Two Rings seangrimes590's Avatar
    Nov 17 2013
    '12 A4 | K04
    Villanova, PA
    If this is indeed the case you need to be careful of high boost / high load situations, running lean is a disaster waiting to happen.
    May 15 2015
    Quote Originally Posted by seangrimes590 View Post
    So you guys recommend changing the fuel filter?
    AKA: NathanMansoor
    Oct 27 2010
    Norwood, MA.
    I would definately start there. Its cheap and easy. How many miles are you currently at? Just out of curiosity.
    2016 S3
    May 15 2015
    About to hit 104k
    AKA: NathanMansoor
    May 15 2015
    **UPDATE**
    Preformed a low amp trickle charge on battery yesterday and it seems to have fixed the draining issue. Haven't gotten any CEL any misfiring or anything. Good those codes may have been a glitch or something?
    AKA: NathanMansoor
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    So my ‘11 A4 2.0T Quattro auto started stuttering under acceleration yesterday. Like it was misfiring or something. Put it in neutral and she purred perfectly all the way up to redline. I’ll throw the Carista on in a few and let you know what i find.
    Sep 27 2016
    NE Ohio
    Feb 24 2013
    CA
    All those codes lead to a bad intake manifold and may be leading to unwanted air into the system
    Sep 27 2016
    NE Ohio
    Yeah trying to find an intake now....
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Quote Originally Posted by B8Brit View Post
    https://www.eeuroparts.com Had the best deal I could find on a b8 intake manifold. I wanted to push my car off a cliff it was running so bad lol
    18' RS3 Stage II and all the Fixn’s
    21' SQ8
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    Mar 25 2018
    Quote Originally Posted by Roadtrippn View Post
    Before you replace the intake manifold, check to make sure it’s faulty. On certain B8s Audi extended the coverage for both the injectors and the intake manifold.
