Results 1 to 7 of 7
    Senior Member Three Rings JimmyS3's Avatar
    Aug 13 2016
    Pennsylvania
    Thinking about 034 rear sub frame inserts
    Pro's
    Con's
    Thanks in advance.
    Jim
    :: 2018 S4 ::
    - 034motorsport - APR - CTS - EMD - ECS - MBRP
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    I had them installed along with the front dogbone.... Can't go wrong on anything 034 makes. top notch quality. Pros are better stability and car feels more 'planted' . I have no cons.... I would highly recommend. I have my car lowered using neuspeed springs along with mag-ride and I am hearing a bit of noise so I am planning on upgrading to 034 strut mounts along with bearing kit in the spring.
    Mar 22 2016
    Las Vegas, NV
    I have 034 Dogbone, sub frame inserts, rear sway bar, rear end links, front adjustable end links. I am waiting on their engine mounts. My car is on B14 Coilovers. No cons imo.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Hi jiannu...
    Did you purchase locally or from 034?
    Thanks
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by bakedcorn View Post
    Hi jiannu...
    Thanks
    purchased all my 034 stuff from Ina industries. They are located in Ottawa. http://www.iabedindustries.com/
    Issam is great to deal with and can answer any questions you have... Prices are fair as well and ships fast.
    Jul 27 2015
    Ontario
    Sweet, thanks
    Sent from my A0001 using Tapatalk
    Aug 13 2016
    Pennsylvania
    Will order them up next week. Will provide feed back a loser after a couple hundred miles.
    Thanks..
    :: 2018 S4 ::
