Thread: Forge dv?
    Established Member Two Rings Jg3's Avatar
    Jun 11 2015
    2005 A4 B6 3.0 cabriolet
    SGV
    Forge dv?
    Does the provided solenoid take place of stock solenoid? If so what about the ports the stock solenoid connected to?
    Sent from my SM-G928V using Tapatalk
    Sep 09 2009
    09 RDX
    Rhode Island
    No, It is additional.
    It is a N75 valve that controls the DV.
    AEM Boost Gauge * Eurocode FMIC * JHM Shiftier * AMR Tune
    Jun 11 2015
    SGV
    Quote Originally Posted by linet90 View Post
    Thanks for reply
    Sent from my SM-T237P using Tapatalk
    Jun 26 2009
    Bremerton WA
    Deleted: didn't realize the forge unit comes with a N75 and a DV.
    VMR 710's, APR software, Eurocode HFC
    Jun 11 2015
    SGV
    Quote Originally Posted by van462 View Post
    The factory electric DV solenoid is separate from the N75. The N75 takes compressed air from the turbo and via commands from the ECU opens the waste gate to regulate turbo shaft speed. The DV s a way to depressurize the intake tract. Adding a vacuum based unit like forge you will need a boost tap. When the throttle body closes intake manifold will go into high vacuum this vacuum will be used to open the DV and depressurize the intake. In the picture it appears to have a dv next to the N75. The DV is further below, the only electrical part on the turbo.
    Thanks.
