Originally Posted by
A4x
Oh, I have not ever seen the B&O midrange for the dash. I guess you should go with some other 3" midrange that can fit in there (you will need to make your own mounting plate). Like I said, the Dayton RS75 fit well for me.
I replaced my door woofers with Rockford Fosgate 6.5", they are listed at 5-60 W RMS. I'm afraid the stock amp cannot push them hard enough. I lost a lot of low end volume by installing these. I will try to go back to the stock 8" woofer. I low-passed the 6.5" at 800 Hz, used a 800Hz-5000 Hz bandpass for the Dayton 3" in the dash, and 5000 Hz high pass for 1" Rockford tweeters. I have a very bright setup now and lacking low end, probably because the 6.5" are not being driven hard enough by the amp.
I also have a 10" JL sub in the trunk which is great, but I need to fix this front staging....ideas?
From my personal experience with car audio, when you replace the door speaker in modern car you always break the sealed enclosure that the OEM speaker has. Most OEM speaker has a plastic frame in the front that match perfectly the door cover, thus making all the output from the front of the speaker to reach the interior of the car, and all the back to be isolated in the door enclosure, this is never possible to realize with aftermarket speaker because we can't fit the front of the speaker flush to the door panel. So the back wave of the speaker will be cancelled by the front wave, thus preventing producing bass. I think you could use a backbox to prevent this but you will not get good bass from that because 6.5" car speaker are designed to work free air. People are wrongly thinking they only have to seal the speaker from the mounting ring, this is not enough because the door panel in part of the door enclosure, not just the door frame. Using a more powerful amp will only make the speaker cone to move a bit more but will not reinforce the bass. With aftermarket in the door, you absolutely need to use a 80-100hz hi-pass cut-off and rely on your sub for the bass.
Also, is your Rockford Fosgate a matching component set? I would never break a matching component set with a speaker from another brand. With a 6.5 in the door, you do not need the Dayton in the dash, just use the Rockford tweeter and the crossover that comes with the kit and I'm sure it will sound better. For best imaging, I do prefer component set with lower crossover frequency around 2500-3000hz, but this is specific to the kit you buy and to your listening preference. Also with stock amp, use lower-end component speakers with higher sensibility (90+db). Hi-end stuff always require powerful amp to deliver output and not always sound better than lower end speakers depending of what you listen and how far you go with you audio install.
I also use a JL sub in the trunk, connected to a small JL HX-series amp that support speaker level input and auto-on/off from signal sensing, piece of cake to install, no remote cable, no LOC adapter needed, it worked out of the box.
