Results 1 to 13 of 13
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Issue with down pipe hitting the transmission crossmember?
    I wanted to see if anyone else is having a issue with their down pipe hitting the transmission cross member? I have a JHM test pipe connected to the JHM down pipe that splits to a Y and then a stock s4 exhaust. For some reason the exhaust under first acceleration and then at different RPM's will touch the cross member and its driving me crazy. I also have 034 engine mounts which at first i thought were too tall and might be the cause but after buying some stock one to test with after putting them next to each other are 1/2 inch shorter. I ended up grinding the cross member to make room which helped but did not completely get rid of the issue. So I'm at the point where i think I'm going to take the cross member off and cut the front part where its touching and weld it back to make more room. Has anyone else have a similar issue?
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
    Dec 23 2011
    There was another recent thread about this. Few people (myself included) had some fitment issues. I had to modify my test pipe to get everything to fit.
    Feb 27 2013
    New York
    Yeah its a tight space for such a large pipe. Did you have to extend the test pipe a little to bring the front down? It looks like that's the only place its touching for me and its not always just at takeoff and at certain RPM's. I think it might just be easier to modify the cross member to give some more room. Actually the 034 engine mounts helped by being a little shorter than stock with the clearance.
    Audi Q3 8U-White
    Dec 23 2011
    Yeah, extended test pipe and angled it so that the downpipe would have clearance.
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2005.5 2.0TQ 6-spd
    Stinky Island, NY
    I had the same issue, same setup except the S4 exhaust is a Sebring Tuning exhaust. When I finished the installation, I found that the exhaust was hitting the left side of the cross-member.
    This was happening because I tightened the center clamps before adjusting the position of the exhaust.
    Once I loosened the clamps, I pulled the exhaust as much to the right as I could to prevent it hitting the cross-member.
    It still looks a little crooked, but I'll fix it when I need to.
    The equally as annoying issue is the exhaust hitting the reinforcement bar. I ultimately removed it and it's sitting in my trunk until I can figure out what I can put in between the exhaust and the re-bar to stop it from slapping every time I hit a bump.
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    Feb 27 2013
    New York
    Thanks for the input, I might try and adjust it some more.
    Audi Q3 8U-White
    Dec 23 2011
    Deusilan, I addressed the reinforcement bar issue by using thick washers in between the reinforcement bar and the car body. That spaced it enough to not rattle against the exhaust
    Jun 17 2013
    jersey city nj
    Here was Jake on the situation
    Quote Originally Posted by Jake@JHM View Post
    When connecting the DP-Y to the TP try tightening the bottom bolt of the 3 hole flange first. That will help bring the natural angle of the system down.
    However, a bad mount that would cause the engine to lean one way or the other can cause this type of issue.
    Aug 17 2012
    Stinky Island, NY
    Quote Originally Posted by p0isin View Post
    I tried some washers, but it didn't work for me. How thick did you go to make sure there's no contact?
    Dec 23 2011
    I can check later today. I may have double stacked them.
    Feb 27 2013
    New York
    So this is how I fixed the issue now no touching.
    Audi Q3 8U-White
    Aug 17 2012
    Stinky Island, NY
    Quote Originally Posted by DeathBlow View Post
    Nice!
    Dec 23 2011
    Can't say I didn't consider doing the same thing when I had that issue.
