Does anyone have any experience with changing the starter on their RS4? I'm pretty sure mine is dead. The reason I ask is I'm debating whether to change it myself or have the car towed to a shop. I rather do it myself to save the labor cost and I really hate seeing my car loaded onto a flatbed. It's so low its impossible not to cringe while they load it. The car is in the garage so it's already in an ideal spot to work on it. So for anyone who can help, my questions are
1) what is the estimated labor time?
2) is it worth the hassle to do it yourself?
3) any tips or issues you've ran into (interference removal, ability to reach mounting bolts, etc)?
The reason I think the starter is dead is my car wouldn't start a few days ago in the morning. It wasn't abnormally cold outside and the car had only sat over the weekend. Taking the key to start there was no attempt of the starter to turn the engine. I've tried several more times since then. I checked battery voltage and its a solid 12Vdc. All other electrical loads are unaffected. If I take the key to run without going to start, wait a moment, then take the key to start, I hear a light hum under the car that sounds a lot like a coil energizing. So it sounds like the start is getting power but isn't spinning. I haven't had a chance to check any codes with VCDS yet.
Prior to this I thought the starter sounded like it had to crank a second or two too long to get the engine to turn over, so it's possible it was on its way out. A new one from JHM is about $200.
Thanks for any help.
reference threads: http://www.audizine.com/forum/showth...hlight=starter
