Results 1 to 40 of 76
    Sep 26 2016
    utah
    Put aside your douchery for one second!
    Alright guys. Put aside your douchery for a second to answer a question.
    Everyone keeps telling me to do a search, and I've searched every topic I know how to.
    How do you install the K&N cone filter? You can get them on amazon for like 20 bucks. What's the process. If there's a how-to, please put a link. But the product I have in mind is this one:
    Do I need anything special for it, and can I just pop it in as easily as the stock filter? Because that little turd was so easy.
    Send me a link to videos, how tos, or post up some stuff of how to do it. I can't find anything anywhere, and I'm not willing to go buy something only to find out that I need another part for it that happens to be like 90 bucks for it. Someone be a decent human being and tell me how it works please.
    Oct 24 2015
    Perth, WA
    Remove stock air box and attach to the intake side of the MAF with the provided hose clip.
    My respray thread
    Sep 26 2016
    utah
    Quote Originally Posted by Okedokey View Post
    That simple? And it just pops on there?
    Oct 24 2015
    Perth, WA
    Yep.
    My respray thread
    Senior Member Two Rings Lanorg's Avatar
    Apr 22 2013
    Floor jacks, torque wrenches, and winter tires
    Match up your intake side size in mm or in to the size intake cone you require. Also double check that the cone filter comes with a worm gear clamp. If not, $1 at a hardware store.
    Something else to ponder might be the placement of the actual cone - do you want an extension on the MAF? How long? With an angle on it?
    B5
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    really easy. If you want to go on a budget :
    *note : you shouldn't gain any hp, you'll might decrease it. But it will worth it for the spool sound. (btw, the turbo sound level increase will be very low)
    You'll need :
    - 3'' aluminum piping. ( I use a 60° from a old nissan ebay intake, test fit it, cut it. )
    - 3''/3'' coupling (for MAF)
    - 3''/2.5'' for turbo intake.
    - the filter (oiled or not, urban legend that can damage maf, at least on all car I've owned and other people on the car scene. quantity is way to low to stick on the sensors )
    1. remove the front plastic intake conduit ( 2 screw visible to the top, out of the engine bay. You can keep it after install)
    2. remove the stock air box with the stock filter.
    3. You can keep or remove the stock intake rubber hose. ( I choose to replace it with aluminum 3'' piping)
    4. Remove the MAF from the stock air box, you need it, see picture for installation position.
    5. fit the cone on the MAF. MAF on the pipe. Pipe on the turbo inlet. You can reuse the conduit from point 1.
    6. optional : heat shield. Will ''help'' to force the air in the cone through the fender intake and the front plastic intake ''instead'' of the hot engine bay.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    You can do all that or I'll sell you my old setup
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    What's your old set up?
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    :facepalm:
    Jul 23 2010
    arizona
    Quote Originally Posted by pezgoon View Post
    Filter and heat shield.
    Jul 25 2016
    new hampshire
    Ah, what did you end up doing instead?
    Eric
    Jul 23 2010
    arizona
    Doesn't fit this very well so I had to change to a new setup.
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    Quote Originally Posted by derrek View Post
    He replaced with a larger intake....
    Jul 25 2016
    new hampshire
    Holy shit! That intake is massive! Is that like 6 inch diameter? Lol
    What kinda turbo is that?
    Eric
    Jul 23 2010
    arizona
    I think it's 3.5in, the turbo is a hta 3076
    Sep 26 2016
    utah
    Update! The new filter is on, and it works fantastically. You can really hear the turbo wind up, and it has not only a better throttle response, but it also seems to be getting a ton more power. I figured it would be a slight difference, but it has truly been phenomenal. I had no idea such a small mod could really have that much effect on it. I'm very very pleased. However, derrek, I would love to see about the old setup you had, and see if it would be worth my time. Pm me about that.
    Jul 25 2016
    new hampshire
    If you scroll up you'll see pictures of it, I decided to pass, I really wanna get ecs tunings intake that essentially seals the intake off from the rest of the engine bay
    Eric
    Apr 24 2016
    California
    Any pics of this installed? Not a fan of the filter but may be interested in the heat shield
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Active Member Two Rings atvhead's Avatar
    Sep 06 2016
    A4
    NH
    Pictures or it didn't happen
    2007 A4 2.0T AWD....100% stock!
    Jul 23 2010
    arizona
    Quote Originally Posted by RakkCity View Post
    There's some in my build thread
    Mar 01 2011
    Nanuet NY
    LOL
    Aug 06 2016
    1952 Chevrolet Styleline Deluxe
    Colorado Springs, CO
    Is that setup still available?
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Must resist.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Jun 27 2011
    Quote Originally Posted by 1killera4 View Post
    :facepalm:
    This.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 27 2011
    Quote Originally Posted by lithiumionssuck View Post
    Hahahahahahahahahaha. Your butt dyno isn't very well calibrated man. Confirmation bias at its finest.
    -CP
    2017 Q7 3.0t
    Feb 22 2016
    Colorado
    I'm sorry to burst your bubble. I've actually noticed a boost in power by switching from the K&N dirt intake to a spectre air intake.
    There was probably about another 2 inches of build up on top of that.
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Guys. Guys! Come on guys. Put aside your douchery. He asked nicely.
    If the man wants to run a HAI, let the man run a HAI.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Apr 24 2016
    California
    Quote Originally Posted by NickSchooler View Post
    You'd feel the same difference just by cleaning out your snow trap and dropping in an OEM filter. Intakes don't add any horsepower, yours just freed up what you were losing by having shit built up in the way.
    Feb 22 2016
    Colorado
    I know. I just like the sound of the turbo.
    Jun 27 2011
    This just in! A new filter flows more air than a reqlly really old dirty filter. We will continue to report on this story as it unfolds.
    FWIW, I guarantee you if you put in a minimum of effort and check the MAF measuring blocks you might see an increase in airflow that likely doesn't exceed the standard error of the sensor. Aka there are no measurable gains. And just do yourself a favor and don't look at IATs at all. That will totally harsh your mellow.
    -CP
    2017 Q7 3.0t
    Senior Member Three Rings mscottdemarco's Avatar
    Jun 29 2013
    had a 13 Audi S8 and a few a4s.. Now have a 15 q7 tdi, and a 19 q5 2l
    Denham Springs, LA 70726
    Shit! I just want to know where can I buy one of these K&N Dirt intakes at? I've been looking all night.. [scratches neck like crackhead] Nick will you sell me yours?
    Apr 24 2016
    California
    Speaking of, what's the acceptable range for intake temps? Specifically the upper limit.
    Mar 18 2014
    Dunedin Florida
    Real dyno or it never happened.
    Jun 27 2011
    The upper limit is when the ECU starts pulling timing to prevent detonation or knock. The limit depends on a number of factors so there isn't really a hard limit.
    -CP
    2017 Q7 3.0t
    Aug 17 2013
    Rossford, Oh
    I love this thread.
    Jul 29 2010
    Calgary, Alberta
    Quote Originally Posted by yeoj112689 View Post
    I love this thread.
    Same. It's like a rite of passage. New guy comes in, gets stoked about his car, wants sweet sweet turbo sounds, hears about cold air intakes, doesn't search, creates asinine thread on subject that's been covered to death, learns that this setup is way fricking worse, defends self claiming huge power gains, world keeps turning until this happens again next year.
    Edit: I forgot to put aside my douchery. Not sorry. Nor am I sorry that I'm not sorry.
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by charles.waite View Post
    this just in! A new filter flows more air than a reqlly really old dirty filter. We will continue to report on this story as it unfolds.
    Fwiw, i guarantee you if you put in a minimum of effort and check the maf measuring blocks you might see an increase in airflow that likely doesn't exceed the standard error of the sensor. Aka there are no measurable gains. And just do yourself a favor and don't look at iats at all. That will totally harsh your mellow.
    win
    Quote Originally Posted by billyhoyle View Post
    same. It's like a rite of passage. New guy comes in, gets stoked about his car, wants sweet sweet turbo sounds, hears about cold air intakes, doesn't search, creates asinine thread on subject that's been covered to death, learns that this setup is way fricking worse, defends self claiming huge power gains, world keeps turning until this happens again next year.
    Edit: I forgot to put aside my douchery. Not sorry. Nor am i sorry that i'm not sorry.
    ning
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Oct 24 2015
    Perth, WA
    My respray thread
    Jun 27 2011
    That's a ttrs (according to the image URL). Transverse engine. Different intake layout. Totally different.
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    I know, but it still shows that a stock air box can/will be restrictive.
    My respray thread
