Bought a ross tech cable finally! Here is the dump of the auto-scan. Still learning how to use the software...
Only thing that stands out is the MAF fault... think this would cause a no-start?
Friday,25,November,2016,15:02:40:14303
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUAF78E26A119003 License Plate: AUDI
Mileage: 179220km-111362mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUAF78E26A119003 Mileage: 179220km-111362miles
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H10--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 22164 444 84353
VCID: 2B55487D8A32EF1A39-807E
1 Fault Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 179228 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.700 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 C HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0010
Revision: 00000008 Serial number: 00000000919175
Coding: 0000001
Shop #: WSC 06335 000 00000
VCID: 285FB7719BC4C402D4-807C
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 26
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
(no units): 1.0
Torque: -54.0 Nm
Temperature: 23.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
2 Faults Found:
18265 - Load Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x4F00
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01AB
Hex Value: 0x0000
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0024
Hex Value: 0x0197
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6CD78B611CBC282270-5140
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 00003
Shop #: WSC 06335
VCID: 3B75783D29527F9AA9-4B00
1 Fault Found:
01518 - Bulb for Back-Up Lights; Left (M16)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N000YX9M
Coding: 0032607
VCID: 3C777B217F5C78A2A0-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 35G3A
Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
Subsystem 4 - Serial number: 000000˙†6332DRB402365327B˙†63
Subsystem 5 - Serial number: 65327B˙†6342DRB4022910187˙†63
Subsystem 6 - Serial number: 910187˙†6352ARB4008FB2A6Y˙†63
Subsystem 7 - Serial number: FB2A6Y˙†6362ARB400AE91E4Z˙†63
Subsystem 8 - Serial number: E91E4Z˙†63729RB400BD1F64X˙†63
Subsystem 9 - Serial number: D1F64X˙†63829RB400BD204CQ˙
Subsystem 10 - Serial number: D204CQ˙
1 Fault Found:
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 15
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02021
Shop #: WSC 06335
VCID: 41890AD54BBE154AF3-4B00
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0022261
Shop #: WSC 22164 512 00000
VCID: 2E534169BA209A321E-515E
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0022261
1 Fault Found:
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11836
Shop #: WSC 06335
VCID: 0407C3C1142CC06298-4B1A
Subsystem 1 - Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0506
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0506
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0506
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
52-10 - Supply Voltage Too High - Intermittent
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 01005
Shop #: WSC 22016
VCID: 2C574B61DC3CE82230-50AE
1 Fault Found:
07-10 - Signal too Low - Intermittent
End-------------------------(Elapsed Time: 07:42)--------------------------
