Results 1 to 4 of 4
    Aug 09 2012
    Bay Area
    P2015 and Major Vacuum Leak
    Multiple codes on for P2015 Intake manifold position sensor implausible signal and about 5 or 6 codes for fuel trim lean codes. Vehicle came in w/o any issues except codes being on. After test driving the vehicle thats when the misfire occurred.
    Here's a video of what I found causing these codes and symptoms:
    Suspect that while driving boost inside the intake is so strong it popped the piece out. At low idle speeds the vacuum built up and was able to suck it back in masking the problem. I got lucky during my test drive that when it blew out it got stuck on the lip causing a massive vacuum leak. Since intake needed to be replaced anyways went ahead and recommended carbon cleaning and spark plugs at the same time. Here's before and afters of my walnut shell cleaning.
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Nice work!
    Sep 09 2010
    Destin, FL
    Too bad we don't have an area where we can put all fault codes and fixes for future reference... Oh wait. Nice work though!
    http://www.audizine.com/forum/showth...ting-and-Fixes
    Aug 09 2012
    Bay Area
    Quote Originally Posted by The Infiltrator View Post
    Ah my apologies. I don't usually frequent other areas besides the B6 section since I own one. My fault.
