Results 1 to 10 of 10
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Which Piston Rings?
    Going to the dealer would cost $150 more for piston rings. Would anyone know if ABA piston rings would fit the 2.0t FSI BWT engine? The bore and stroke are exactly the same. I'm looking at Hastings 2C4639 piston rings which cost $100, and the ring specs are as follows: top comp ring: 1.2mm, second comp ring: 1.5mm, oil ring 2.0mm.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Why not just get 4 of these?
    https://www.europaparts.com/piston-r...6d198151e.html
    Edit:
    Nvmd. I see the sold out now. That was a good price they have.
    Jan 24 2013
    Chicago
    Quote Originally Posted by onedumslack View Post
    That's the thing. I can't find the Mahle rings anywhere. It's like they stopped making them, and the only place to get some is OE dealer rings.
    Mar 05 2014
    phoenix/az/usa
    Quote Originally Posted by Denio24 View Post
    Ebay search for the part number yields alternatives labeled for other models with the same part number. Might have some luck there:
    06D198151E
    Jan 24 2013
    Chicago
    Just did some internet digging and it looks like someone with a b6 passat 2.0t fsi used the Mahle 41926CP piston ring set. Anyone looking to purchase some rings they are 71.99 from rockauto for a complete 4 cylinder set: LINK These rings are plasma moly faced so I think i will finish with 320 grit 3 1/4" flex hone. If the cylinder is out of round then I'll have to take it to the machine shop
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Have you contacted Mahle?
    Jun 27 2011
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 24 2013
    Chicago
    I'd rather buy Mahle pistons rings. Anyway, I found the ones I need as I posted above. Mahle piston rings are HCS, cast iron, and SS for the compression rings and the oil rings, respectively. It's weird that despite having the same engine the application tables are different. I called Europaparts a while back and they said they ordered a bunch of rings but it is back ordered to an indefinite amount of time.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Bump....Having the exact same issue. OP, what did you ultimately do?
    The Mahle rings seems like the best (and least expensive option), but you can no longer source them...Sold out everywhere.
    The next best thing I can find is for 4 x OEM from FCP;
    https://www.fcpeuro.com/products/aud...vag-06d198151e
    I have a BPG engine FYI.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Jan 24 2013
    Chicago
    Quote Originally Posted by BenMTL View Post
    The N/A rings also fit our stock pistons, just make sure they're gapped appropriately.. This is Mahle/Clevite Part #41926CP. I no longer use stock pistons and use a different ring kit.
