Results 1 to 21 of 21
    Sep 29 2016
    Longwood, FL
    At a loss for the problem...
    My wife has a 2008 Audi A4 2.0t and just recently started having problems.... I replaced the gas cap and the N80 EVAP Valve but am still occurring the problem of it not starting. It is making the clicking noise as if the battery were dead but I just replaced the battery and load tested it last night, its not the battery. When I go to turn it on ACC, my CEL, battery light and EPC light are on. I go to crank it, no turnover, just the clicking of a dead battery. After I try, it locks the ignition and you have to remove the key to try again.... also after I try, you can hear a slight beeping noise in the engine compartment for maybe 5-7 seconds and then it stops. I've checked all the fuses, all are good. I've looked at the starter to see if the wire has corroded, wire is good. I'm going to test the starter tonight with a test light and see if it is the solenoid maybe and try banging the starter if the solenoid is good but if this fails I don't know where else to go.... I've searched and searched on here but haven't found a thing EXACTLY to what I am experiencing but I did find a few things, hence me changing the EVAP purge and the gas cap. Please help..... I appreciate your time, thank you in advance!!
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    When trying to start the car, is it giving you repetitive clicks or just one solid click?
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Quote Originally Posted by presco135 View Post
    I would say test the starter. Is it automatic? if manual try to push start. Gas Cap and N80 would not cause the car not to crank.
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    manual? if yes, get few friends and push it to do a compression start. It will take less time to diagnose the starter.
    but seems to be the starter.
    beeping noise might be the fuel system being primed.
    On 'ON'', cel and esp light will come on, at least on my car it does.
    * edit, brandon was faster than me on that one
    Sep 29 2016
    Longwood, FL
    Quote Originally Posted by miA4 View Post
    It is repetitive clicks and a slight hum/buzz but I let off after a second or two to not damage anything. Unfortunately it is automatic or I would've done that already :( one good thing about manuals! LOL
    Sep 29 2016
    Longwood, FL
    Quote Originally Posted by brandonpham View Post
    My main reasoning for replacing the gas cap and N80 was because after she would fill up the car wouldn't always start so hopefully I solved that problem now.... but now to get it started in general
    Nov 15 2011
    Montreal | I sell in USD
    *****I sell in USD*****
    Jul 01 2015
    Mtl
    Quote Originally Posted by Axis View Post
    wtf, can't click : blocked .
    The link you are accessing has been blocked because it contains content belonging to the category of: Adult Content
    If you believe this is an error or need to access this link please contact your administrator.
    what did you do?
    Dec 07 2014
    Quote Originally Posted by oVeRdOsE View Post
    what did you do?
    He's just doing Rule 22: Urban Dictionary.
    Axis getting this man in trouble at work. Now IT is gonna call him up to their office.
    Nov 15 2011
    Worst is, the IT dept is probably browsing midget porn while he can't access UD lol
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    My B6 did a similar thing when the oil pump went. but i got an oil warning.
    Senior Member Two Rings lockeed's Avatar
    Feb 06 2010
    Quebec
    Remove the protective shield under the engine bay, towards the passenger side of the car you'll see the starter, check the terminals and electrical connections on it which are prone to oxidation. Disconnect the battery, remove and clean each wire, if possible with acid, then reconnect and re-try.
    Sun: E90 M3 6MT or E46 M3 6MT // Snow: B8.5 A4 S-line Quattro
    Sep 29 2016
    Longwood, FL
    I did that already, all terminals on the battery are in perfect condition, replaced them about 2 months ago due to them going bad and corroding so figured since I'm changing the battery might as well put new terminals. For the starter all wires are in perfect condition. I took a video of what it is doing when you turn it over.... let me know what anyone thinks please. Here is the link https://youtu.be/OGIH0XhQhng
    Jul 17 2015
    miami
    Disconnect the starter and test it. Just because the wires are fine, doesn't mean the internals are working correctly.
    Feb 06 2010
    Quebec
    Sound like an internal problem. Probably the bendix.
    Dec 07 2014
    Did you try hitting the starter with something while having someone start it? Sounds like the starter bud.
    Sep 29 2016
    Longwood, FL
    Yeah I took a ball pin hammer and tapped it while starting but never cranked. If it is the starter it is converted under warranty so off to the dealer it goes... how can the starter be tested with a test light? Can it? Thanks for all the help people
    Jul 17 2015
    miami
    It can be tested by removing it and going to an auto parts store. they can test it.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Bingo
    Also hitting it doesn't always work, we had a forklift at work that had a bad starter, sometimes hitting it worked, other times it helped you just kill time with an excuse
    "I'm trying to get that customer boss but the damn thing just won't start!"
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Sep 29 2016
    Longwood, FL
    Solved the problem.... bad solenoid on the starter and replaced the spark plugs. She's running like a beaut again. Thanks for all the help everyone!
    Oct 24 2015
    Perth, WA
    Thanks for providing the solution.
    My respray thread
