Results 1 to 11 of 11
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: Not Too Stiff.. Not Too Soft.. Just Right...
    The ECS Tuning performance rear differential mount insert kit was engineered in-house by our industry leading R&D department, resulting in countless hours of research and testing to establish the best possible design for minimizing driveline deflection while retaining the vehicles everyday driving comfort.
    ECS Tuning's primary goal was to achieve a comfortable and compliant ride while maximizing performance, and real world test miles put down on multiple vehicles has proven just that.
    Installation can be completed within 30 minutes in your own garage.
    Features include:
    • Significant reduction in rear differential movement
    • Billet & black anodized 6061-T6 washers for durability and corrosion resistance.
    • Polyurethane differential carrier insert to reduce drivetrain deflection while keeping noise vibrations associated with such modification to a minimum
    • Increased drivetrain rigidity and response
    • Long-term testing performed on multiple vehicles for real-world qualification
    Increased drivetrain rigidity and response.
    Fits:
    Audi B6 A4 1.8T 2002-2005
    Audi B6 S4 2004-2005
    Audi B7 A4 2.0T 2005.5-2008
    Audi B7 S4 2005.5-2008
    Audi B7 RS4 2007-2008
    Be sure to check out our -----> Installation PDF <-----
    Jason
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Im glad to see another option that is for those of us that are more comfort oriented. Also, I really like your installation instructions with links to the tools you need and good pictures too.
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Interesting. The differential carrier inserts seem to be a different material from the 034 ones (Polyurethane vs. Billet Aluminum) and $30 cheaper too. Any idea how the polyurethane would compare to Billet Aluminum when it comes to reducing NVH?
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Oct 02 2006
    Wadsworth,OH
    Poly will definitely transfer much less NVH than Billet.
    Jason
    Oct 11 2007
    Suburbia
    It's probably a compromise between stock and 034's offering.
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Oct 02 2006
    Wadsworth,OH
    Exactly.
    Jason
    Oct 02 2006
    Wadsworth,OH
    All ECS products on sale until 1/2/17!! Don't miss your chance to save on great products!!
    Jason
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    What's the difference in performance/functionality of the bushing insert kit only vs the entire rear diff mount kit?
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by R&Cs4 View Post
    The entire kit is going to provide the maximum stiffness in the differential as it's also replacing the rear diff mount. Carrier bushings inserts are going to stiffen the system with minimal NVH increase.
    Oct 19 2009
    Great, thanks
    '11 S4 6MT
    '58 Auto Union 1000
    '54 Corvette
    '64 GAZ 69M
    Atlas R-Line
    IG @this_is_r0b
