Results 1 to 9 of 9
    Jun 11 2011
    Question Endlinks replacement only - need new bolts?
    Thanks.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Are you asking if you need new bolts or if someone else needs the new bolts you have?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by phanker View Post
    Thanks.
    OEM repair manual states to replace.
    Jun 11 2011
    Does changing end links require removing existing bolts? Can't reuse them apparently, thus requiring new bolts.
    Oct 14 2012
    Empty...for now...
    SE PA
    The endlinks connect to the sway bar and control arm with bolts, so to removing the endlink requires removing the bolts. The bolts are "torque to yield", or "stretch bolts", meaning that when the bolt is installed it is torqued to the point of stretching the bolt to achieve a high enough tension to make the bolt self-locking. Technically they should be used only once.
    I have removed and reinstalled these exact bolts multiple times on my B8.5. Each time I've removed them, I've had to apply breaking torque that feels like the same torque I used to install them, but I cannot prove that the torque is the same. What I can say with confidence is that I have not had one come loose.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Are you suppose to? Yes. Reality is a little different.
    After doing my front brakes I replaced all the stretch bolts holding the carrier to the hub. Examining the new bolts vs the old ones I couldn't notice any evidence of strain but had new ones anyways.
    Much would be the same for the suspension bolts I assume.
    Edit: Just thinking, the bolts are "torque to yield" however steel can yield and not reach deformation, meaning the material can reach a yield point without showing signs of deformation (stretching). I doubt we are anywhere near the stresses required to stretch the bolt, but some yielding may be present. I thinks its the Germans being German...
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by SDV325 View Post
    Agreed. If I were really concerned about it (which I'm not), I would add removable thread locking compound to the threads of each bolt for extra assurance that it does not back out.
    If you think the dealer installs new hardware when ever they remove stretch bolts, think again...
    Edit: not saying it's NOT a good idea to do so...
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I re-used old endlink bolts (and endlinks), front and rear, no problems for 20,000 miles so far, with the stiffer EuroCode bars, both set to the stiff setting.
