Results 1 to 4 of 4
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Rear window (windshield) seal
    I can't seem to find anything on this. Has anyone replaced their rear window shield seal without removing the glass? I plan on having my car sprayed in a different color, and would like to paint behind this. If it cant be removed without pulling the rear windshield, I suppose Ill just have to go that route. If thats the case, has anyone pulled the rear window themselves?
    Link to seal in question: https://www.ecstuning.com/b-genuine-...eal/8e5845522/
    Aug 26 2005
    The window is bonded to the body and butyl boding adhesive forms the seal of the window on the body. You will have to remove the window by cutting through the adhesive to paint behind the window.
    Vorsprung durch Technik
    Oct 07 2008
    05’ GLI 1.8T_4motion, 07’ A4 3.2_quattro
    Calgary, AB.
    Quote Originally Posted by mauromj View Post
    I’ve been wondering about the removal process too - need to pull/clean both the front and back for new glass...
    Jul 23 2012
    Pullman, WA
    So it sounds like the glass needs removed in order to change out the rubber seal that I linked to above?
