Results 1 to 4 of 4
    Senior Member Two Rings audimanstan's Avatar
    May 04 2014
    Indiana
    Instrumental Cluster Flash
    Recently my cluster started to flash at totally random times, no patter what so ever sometimes fast flash sometimes once in awhile, sometimes my screen looks like a scene out of Matrix with numbers and letters everywhere but when it does start messing up there are always randoms bars at the bottom. Sometimes the whole row is full of bars at times just a couple. Any advice where to start looking for the problem? Planning to take it out this weekend and inspect the whole instrumental cluster. [IMG][/IMG]
    Oct 24 2015
    Perth, WA
    Probably damaged ribbon that connects the screen to the circuit board. Check it hasn't come unseated and replace if necessary.
    My respray thread
    Active Member Two Rings Dedsec's Avatar
    Apr 06 2015
    Sweden
    Quote Originally Posted by Okedokey View Post
    Exactly my thoughts...
    Right beneath the LCD display are 2 rubber ribbons which contain tiny wires for connectivity.
    Unmount all and check the (metal) frame around screen, which sets pressure on the screen, is not loose in anyway.
    See pic for frame...
    Documentation is like sex, if it's good, it's REALLY good but if it's bad, still better than nothing.
    Project "Audi R4 - That hacked car"
    May 04 2014
    Indiana
    Thank you so much, I will be checking it this weekend. I will post with what I find! Thank you so much for the pic!
