Results 1 to 16 of 16
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Fuel smell in engine valley, help!
    Hey everyone,
    After removing the supercharger and going back to N/A I'm getting a fresh fuel smell from the right fuel rail towards the back of the motor "valley" (firewall side). I've done a few carbon cleans in the past where I've removed and re-installed the fuel rails myself with no issues. This time it's different.
    I installed 8 new injectors, 2 new fuel pressure regulators, thrust sensor and 2 HPFPs. On top of the motor there is no leak on any of the fuel line connections, sniffing around the engine bay I can pinpoint the strongest smell as mentioned, the right side towards the back of the motor "valley". I already took everything apart for a 2nd time, disconnected the fuel rails and lines, reinstalled all fuel injectors and made sure there is no pinched seal.... I took my time tightening the lines with no stress and torqued the fittings to spec.
    Car runs great and strong, not a stutter or shake from the motor. No codes...
    Any ideas? I'm stumped now...
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Hmm, that is bizzare. I know this may sound silly but perhaps its just residual fuel from the disconnect/re-installs, maybe it just needs to air out?
    "Brake last, finish first."
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Happened to me when i didn't tighten one of the pressure sensors enough. It was the one closest to the front of the car. Those sensors take more torque than you think.
    Get a borescope and look around under the IM with the car running
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    x2 for letting any residual evaporate. Although gasoline evaporates quickly, some of the detergents in it leave residue that may still smell for a bit. Normal fuel trims and whatnot, I assume?
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    pull the manifold back off.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by your daddy View Post
    Unfortunately you have no choice other than doing that again. Take everything off again and clean everything really well.
    If you have a leak then you will know because fuel goes everywhere!
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Quote Originally Posted by JimmyBones View Post
    OP wrote - "I already took everything apart for a 2nd time, disconnected the fuel rails and lines, reinstalled all fuel injectors and made sure there is no pinched seal..."
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by ven0m View Post
    I don't play around when it comes to a potential fuel leak. Setting something on fire is no fun.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    Do you have phenolic spacers installed? If so, check the fuel distribution block in front of the oil filter housing. Those connections can get cross threaded and or tweaked a bit and can lead to a fuel leak. If okay then I'd also suggest pulling the I/M for inspection.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Jan 29 2006
    08 RS4
    Thanks for all the suggestions everyone. NY07RS4 I did not install the spacers this time around, I'm running the stock tune for now.
    I took off the IM again and checked every connection and I found the culprit... brass fuel pressure regulators on the fuel rails still had more to go to be tight, I torqued all of the fuel line fittings but must have missed torquing those. Just went for a test drive and no fuel smell!
    Thanks again all.
    Jan 29 2006
    08 RS4
    PS.. I timed myself take the IM off and on, including getting the tools out and putting them away. Took me 2 hours exactly. Has anyone timed themselves before? lol
    Jun 25 2009
    SC
    I can do it about 45-60 minutes, but I deleted the SAI stuff and all the vacuum lines up front
    May 10 2015
    Slovenia
    Quote Originally Posted by KryptoniK View Post
    Took me a complete afternoon, when removing it for the first time.
    I was missing a shallow bit driver for the bolts at the firewall. Had to jump to the store to get one. Also labelled all hoses and connectors appropriately + took pictures as not to get anything mixed when doing it the first time.
    Now I would be confident to get it on/off in 4-5 hours.
    I tend to take my time and check everything in between as not to forget anything and clear my head. Over the years of working in various electro mechanical fields I've learned that I don't have the time to rush a job.
    That's the correct and smart way. I agree.
    James May: "Yes."
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by komseh View Post
    You guys are like a Nascar pit crew. Who wants to come over next time I do a CC? I can compensate with many beers.
    Jan 29 2006
    08 RS4
    Quote Originally Posted by NYC_Legacy View Post
    Haha, let's set it up!
    Active Member Three Rings
    Jan 11 2014
    Internet
    Seriously. 45-120 is nuts. Shout out Komseh and Kryptonik.
