Results 1 to 17 of 17
Thread: Creaking
    Feb 01 2016
    09 A6 3.0T (Sold), 11 Cooper ALL4 S, 2013 S5
    Lowell, MA
    Creaking
    And for once it's not my bones!!
    I'm noticing recently creaking and it's hard to narrow down from exactly where on the car.
    It is very easily treated by a sudden increase in radio volume however in the interests of good practice I think I should probably try to find out why.
    So, my first question...
    This seems to have happened at about the same time as I changed wheels, both sets were identical size 19x8.5 and the only difference between them was that I went from 45 offset to a 35.
    Is it possible this could have had any bearing on this?
    Cheers
    2013 S5, B&O, Sports Diff, Nav Plus, Carbon inlays, Akebono, APR Stage 2, Dual Pulley, DSG Tune, APR intake and back pipe. KW HAS. Variant 20x10, Carbon Imports rear spoiler, RS Grill, Passport 9500i and night surveillance by Blackvue :) Ultracharger and Intercooler, ECS X-pipe
    Jul 17 2011
    Sin City, USA
    Mick-
    I don't believe your change in wheels would create a creaking noise. As for bearings, when those start to fail you will hear a low rumble or drone that varies with speed.
    Has the temp in your area changed (dropped) recently? I will experience some "creaking" in the front suspension when turning the wheel on cold mornings. When does it occur?
    '09 C6.5 A6
    Feb 01 2016
    Lowell, MA
    Sorry I misled you, I wasn't suggesting bearings, I meant had any implication.
    Mostly during slowdown or pickup, almost like the body flexing if that makes any sense.
    It's true the temperature is headed south but not to the sort of degree where I'd expect to hear brittle noises.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Take a look at the sway bars. A common culprit on our cars.
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Feb 01 2016
    Lowell, MA
    Thanks and will do.
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    Mick, I have been experiencing creaking for a good two months now but I haven't got around to fixing it. I had the car on jackstands and turned the wheel and found that the sway bar end links are the thing causing the noise in my case
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Feb 01 2016
    Lowell, MA
    Thanks 2010 and all.
    I'll take a look.
    In fairness it has been observed that I can completely fail to hear my wife at 2 feet away, but, hear a pin drop in the car
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by 2010A6 View Post
    Like others have said, try this first. These are big heavy cars and the sway bar links take a lot of stress over time.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Mar 10 2015
    Albany, NY
    Quote Originally Posted by D's Avant View Post
    Just curious, as I am no expert yet by far, how long should/do they typically last before you should replace them? My car is a '10 (duh) with 90k
    Oct 03 2007
    02 BMW 330i
    Illinois
    I replaced mine at 70K, depends how aggressive you drive, road conditions, is your driveway steep with a sharp turn, are you running stiffer sway bars? 90K, these are likely done or close to it IMO.
    Mar 10 2015
    Albany, NY
    I can't speak for the previous owner, but I drive fairly aggressively and I do know I put more miles/year on than they did. Had a couple gift cards after my coilover purchase so ECS tuning is shipping them this way as we speak
    Feb 01 2016
    Lowell, MA
    The end links?
    I haven't looked at all yet, but if it is that, is any Audi only tool required, or is a straight forward process?
    Mar 10 2015
    Albany, NY
    Nope just a socket set. Not sure of the exact size but it's just two bolts with a nut on the backside each.
    Mar 10 2015
    Albany, NY
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Is this a different than a body creak? I feel like I hear the body of my car creak when I turn 90 degrees from one hard hill to another?
    If your going to swap out the F/R sways would you do endlinks and bushings at the same time?
    Anyone have experience using non-OEM parts? Its crazy that you can get a kit (front) for $35 while Audi links (font) go at $125/side
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Feb 01 2016
    Lowell, MA
    Thanks 2010, I think mine is getting worse but that could be my mind playing tricks, and notice occasionally when turning a corner.
    90% of the time I think it's at the front and then just occasionally it feels like it's behind me.
    Jul 17 2011
    Sin City, USA
    Creaking
    Quote Originally Posted by se.farrell View Post
    I just installed an entire front suspension (control arms, tie rod ends, C-Links). I sourced it from FCPEuro. It was a Meyle HD kit. It is built to exceed OEM specifications. I highly recommend them.
    As for doing the sways, it is not necessary to replace the C-Links, but it is not a bad idea to do it since you are already in there.
    '09 C6.5 A6
