    Established Member Two Rings mcgough52's Avatar
    May 13 2016
    Tampa, FL
    B8 A4 20" Wheels on Sport Suspension
    Ok..... I know that I probably could have found the answer if I kept searching.... but I'm having a hard time find pictures or testimonials of those with a B8.5 or B8 A4 with the Sport Suspension that are running on 20" wheels with no further suspension mods. If so, can you post your tire specs as well? Or at least maybe point me to the place I should have found had I kept searching? Sorry guys I'm still new to this and pretty much any forum
    2014 S6 Prestige | Mythos Black Metallic | Black Optics Grille | DS1 Stage 1 | Boosted Euro TCU | ECS Intake
    Avante Garde M590 20 X 8.5" ET32 | Continental Extremecontact Sport 255/35/20
    [SOLD] B8.5 A4 P+ 6MT w/Sport Package..... all the mods that made it just right
    Jul 07 2009
    Alexandria, VA
    2014 allroad on Sline springs, OEM struts with RS5 20" wheels - no issues at all. Ride is a bit firmer than stock, but not jarring (the wife would let me know). Tire specs in signature.
    Present
    2018 S5 Sportback - Navarra Blue/Rotor Gray, Prestige
    2015 Toyota Highlander Limited Platnium - Family Car
    1978 Toyota FJ40 - Mustard
    1962 Porsche 356 - Red/Black
    Past
    2014 allroad - Monsoon Grey/Black, Premium +Bilstein PSS10, SPC Control Arms, 20" OEM RS5, Canvasback Liner, OEM Rear Window Sunshade Inserts, VAGCOM Mods
    2007 S4 Cabriolet 6MT (x2)
    Dec 01 2011
    Allroad will be much different than an A4 sedan/avant on 20's, the Allroad fits closer to an A6
    OP if you're just looking for tire specs for 20" wheels, the factory size for that would be 255/30/20
    IG @theshawon
    May 13 2016
    Tampa, FL
    Quote Originally Posted by Liquid Smoke View Post
    That's the tire size I was hoping to avoid as there are not many options at that size. I was hoping to see someone running 255/35/20's, like S4BlackCab, as there are MANY more tire options available at that size. BTW, the wheels that I am interested in are Renn Motorsport RS-71 20" x 9" ET38.
    Dec 01 2011
    Quote Originally Posted by mcgough52 View Post
    if you're on stock height then you should be fine with 255/35 as well, and it will provide a bit more tire to protect the wheel as well, so that will work fine. you could also check out 245/35 as well so it's sort of in between the stock size and that one.
    IG @theshawon
