Hey all,
I have an 2003 3.0L quattro and i need a little assistance with a dipped headlight error. I have done a fair amount of reading about this issue and i yet i have not seen anything quite like my symptoms. HID lights, both lights work and have never had an issue with either one going out. So here is what i have going on.
The dipped headlight icon is almost always on, and it does not say whether it is the left or right headlight. Occasionally it will go away and display the radio station information. But more often than not, the icon is on the display. When it goes from showing the radio info to dipped headlight error, there is a nice loud beep.
Then, 80% of the time, the error icon is on the display and doesnt really do anything but the initial loud beep on engine start up.
For 20% of the time, the loud beep is always happening. Beep quiet beep quiet etc. If i accelerate hard in this condition, the beep will be delayed but as soon as i let up, the beep happens. When it is in this state, turning the headlights on gets the beeping to stop but the dipped icon is still displayed.
When turning the headlights on, there does not seem to be any motion of the headlights. From what i have read, if i turn the headlights on before starting the car, the headlights should move down and then back up again to settle into place. This does not happen. Although i have also never been able to test this with out the dipped headlight error so perhaps the error supersedes the attempt at moving the headlights?
I have looked at tons of posts here including this one: http://www.audizine.com/forum/showth...Leveling-Light Looking at post #12 and comparing the headlight adjustment sensor in post 12 to how it is set up on my car, it seems as though my car has the adjutment arm on the back of the A-arm. I swapped it to the front but didnt change the error.
With out a VAG-Com is there a way to determine if its on the left, right or overall headlight adjustment sensor circuit? Also where is the headlight control module located, as it seems this is almost like a loose connection. I have removed and reseated both adjustment sensor connections and that didnt make a difference.
My plan is to take the headlights out and have a look at the insides. Perhaps there is something in there that is preventing the headlights from moving and throwing an error. Im really at a loss after browsing and trying a lot of different things on this forum.
Thanks for taking the time to read and (hopefully) respond to my post with an idea of what to try next.
-Erik
