Results 1 to 8 of 8
    Aug 12 2015
    Minneapolis MN
    Brake Ducting - Any performance testing?
    I've been reading over the threads of people who have added brake ducts to their S4's. Wondering if anyone has done so and if so did you notice any improvement? Really not needed unless you track your car which I do so was looking at that as a next step after adding the BBK.
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Apr 05 2016
    Portland, OR
    It looks like a pretty cheap improvement, so I am also considering it.
    There is more than enough carnage in the track drivers thread to justify it:
    No one has posted any reviews after installing them from what I can see but it certainly help.
    Geoff
    Aug 12 2015
    Minneapolis MN
    I did that a month ago to my brakes...gotta check thickness more regularly at the track...lol
    Apr 05 2016
    Portland, OR
    Maybe if we can get enough interest we can have ECS or someone else put together a kit for us.
    Assume it is priced well you can count me in on a kit.
    Geoff
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by whiped View Post
    I think ECS has the Macan air deflectors and clamps. The NACA ducts have to be bought elsewhere as well as the hose.. Maybe they can source all of it... I'm surprised no one has put out a complete kit yet...
    Apr 01 2016
    E38 750IL, VW Polo 1.2TSI
    India
    Looking forward for the brake ducts kit to come out.
    Sent from my ONE A2003 using Tapatalk
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Now that is awesome. Had a set of EBC pads do that to me, not in the S4. Proper track pads helps a lot with that but increased air flow does a lot as well. Especially in heavier cars.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Nov 12 2015
    Here
    Quote Originally Posted by cspcrx View Post
    This is the problem. These cars weight two freaking tons.
    FWIW, the B7 RS4 had a nice OEM brake duct set up with inlets in the fog grills.
    Mein ist grau
