Results 1 to 3 of 3
    Senior Member Two Rings Concker's Avatar
    Jun 16 2012
    Norway
    Camshaft sensor G40
    Hello.
    My car suddenly became a little harder to start, need to hold it for like 4-5secs then it starts and works like normal.
    The car is an 2000 S6 Avant (4.2V8)
    I read out the fault codes and it showed G40 Camshaft sensor open/short.
    So i looked it up and seems to be the issue, as i find alot of similar cases.
    However i have ordered one sensor now, as i see its one located under the coolant tank.
    But on a diagram i found:
    It looks like there may be one infront of the cam aswell on the other side?
    This could however be wrong diagram / another model.
    So basically can any1 confirm if there are only 1, or is it 2 on the S6 4.2 Engine?
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    There is one on each head as shown in the diagram ... the heads are basically flipped around from driver's to passenger side. Same thing with the cam chain tensioners ...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jun 16 2012
    Norway
    Quote Originally Posted by 02 A6 2.7T View Post
    Alright thank you :)
    Going to replace both then since they are kinda cheap :)
