Results 1 to 17 of 17
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    What E85/93 Blend are you using for Daily Driving?
    Ive seen this topic brought up on many different threads, but it seems to be aimed more around track/drag Blends. Im lucky enough to have a Super Walmart less than 1/4 mile away that carries E85/E15/93. I typically blend in about 2 gallons for every full tank.
    What about you?
    JVB
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Registered User Four Rings
    Sep 06 2007
    Quote Originally Posted by withENEMYin View Post
    What about you?
    JVB
    Typically walmart gas (murphy's) is some of the worst fuel we've tested... Just an fyi.
    Jun 12 2015
    CA
    I DD with 70% E85 and 30% 91.
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    I do about 3 gallons E85 on a fill up of 93.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    What about you?
    JVB
    On your pulley set-up, I would not go above E25 on a GIAC file at the moment until they revise a few fuel tables (in the works).
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jul 24 2014
    Quote Originally Posted by Loe View Post
    Thanks Loe, what would you suggest? I started doing it this month and noticed a (positive)difference right away.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by tgsweat View Post
    Ditto. No issues and a noticeable benefit in hot weather.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    93 plus 5.5 Gallons of E85...
    Jul 24 2014
    Quote Originally Posted by Tony@EPL View Post
    Hey Tony, Do you have any data you can provide around this?
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    5 gallons of e85 with 10 gallons of 91 octane, but I needed a hpfp to keep up with my dual pulley tune.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Junior Member Two Rings
    Jul 16 2007
    IL
    I'll do 5 gal of E85 and fill the rest with 93 every few fill ups. Running GIAC's race tune with the E85 mix (stage 2).
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    I've been running 2.5 gallons E85 with the rest being 91 for almost two years now.
    2012 S4 (sold)
    Sep 06 2007
    Yes, I have logs from the car I was tuning. Correction factors were double on murphys/walmart over I believe BP.
    Edit:
    Was curious to see if any other enthusiast community had documented this.... first google search return.
    http://www.cherokeesrt8.com/forums/645762-post4.html
    Jul 24 2014
    Edit:
    Thanks for the heads up, if you can share any hard data that would be awesome. I will do some more research around it.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    5.3 E85, rest 93 on the race file
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Edit:
    Shell is bad?! That was pretty much all I put in the S4 haha!
    Jul 24 2014
    Quote Originally Posted by The Fat Kid View Post
    Much of what i see is personal opinion, and have yet to see any hard facts. The link above was also from October 2010...
