Results 1 to 7 of 7
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Bluetooth Connection Drops
    I have an iPhone 6S Plus. Since I updated it to iOS 10 the Bluetooth connection has been dropping. Has anyone else had his issue?
    Established Member Three Rings hurricanes28's Avatar
    Sep 29 2015
    Slingshot pearl black
    Massachusetts
    No issues with my iPhone 7 you have to update the Bluetooth
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I just got my 7+ as well, and can't report any issues in the car. Occasionally my bluetooth headphones for the gym don't connect the first time, but not every time and they connect the second time. There will definitely be a release to address first gen iOS 10 issues.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Sep 12 2016
    Natick/MA
    I use both the 7,6plus and never seen a drop with them they are currently running 10.0.2 iOS version.
    I would say back up ur iPhone ... reset it to factory and then try again. Or may be try it with a different device iPad or something before trying to reset ur iPhone.
    Sep 29 2015
    Massachusetts
    I would also agree in updating the phone to 10.0.2 and download the latest for the iTunes CarPlay. Doing latest software is better because it will fix any issues
    Mar 07 2004
    Charleston, W.V.
    I updated to 10.1 and it's still doing it. I'll be getting the 7 plus soon so hopefully that fixes it.
    May 31 2016
    Mexico
    http://www.gottabemobile.com/2016/09...roblems-fixes/
    Seems like your not alone. Try forgetting the Bluetooth device in your iPhone. then connect to it again.
    If that doesn't work, reset all network settings. And as a last resort, if that doesn't work, reset all settings.
