Results 1 to 7 of 7
    Active Member Two Rings hagerty47's Avatar
    Jan 08 2016
    Orange County, CA
    2008 A4 - Extremely Rough Idle
    On my way to class just now and I'm pulling in and I notice the car idles extremely rough.
    I took a video from my phone so hopefully it shows up.
    I'm hoping it's the coil packs but from how aggressive it is I think it may be the PCV. I'm not too sure so if someone could watch the video and try to point me in the right direction that would be awesome.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Scan the car, come back with the codes
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    make sure your dipstick is seated all the way in? Sound like a vac leak to me.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jan 08 2016
    Orange County, CA
    Quote Originally Posted by Luis_Heineken View Post
    Forgot to mention, it's not throwing any codes.
    Jan 08 2016
    Orange County, CA
    Quote Originally Posted by Denio24 View Post
    Checked the dipstick and oil cap, both were seated correctly.
    May 01 2015
    Mont Clare PA
    This happened to my car a while back and it would only idle real rough occasionally for a few minutes and then run normal. Once it happened I changed the spark plugs and coil packs, ran fine for a while and then I started getting a high idle and my N80 purge valve was bad. replaced that and has been running fine ever since.
    Would definitely look into the plugs/coils and the $10 N80.. the N80 takes literally like 10 minutes to replace.
    Jan 24 2013
    Chicago
    There may not be any check engine lights, but there may be stored codes. Did you scan with vcds?
    Sent from my SM-G920P using Tapatalk
