More Photos: http://cnj.craigslist.org/cto/5802332679.html
For Sale is a 2004 Audi A4 Quattro 1.8t with a 6 spd. With Tons of Free Extras!!
Brilliant Black Exterior, Black Leather Interior.
Second owner and have had the car for 3 years which has been an absolute dream.
Runs and Drives Great plus is a ton of fun!
Asking $10,500 For everything listed below.
I bought the car with 82,xxx miles. The seller told me timing belt had just been done which was true because I looked and the belt was new on the car. At about 87,000 the plastic waterpump they use exploded and blew the motor. I replaced the motor with the same 1.8T w/ 72k miles. During that time I did the timing belt and updated metal impeller water pump. I also replaced the clutch and all gaskets and clamps and seals on the motor. I have had absolutely no issues since then. After the swap the body and trans have 103,100 and the motor is at 88,100 give or take. So you will not have to worry about timing belt until about 157,000.
Engine: 1.8T w/ 6 speed Manual. 88,xxx
Evo Stage 1 ECU Tune makes 18psi of boost.
Catless exhaust with no check engine light and passed inspection good until 2017.
Forge Splitter Valve.
Valve Covers done winter 2015
Coolant Flange replaced at 95,560
Fuel Pump / Filter replaced at 85,193
Stop light switch replaced just at 103,00
Suspension: Airlift Kit with V2 Management installed about 7,000 miles ago
Front Inner CV boot done at 94,225
New Upper Control Arms Installed just at 103,000
Lower Control arm replaced at 101,327
L/R Wheel Bearing replaced at 101,327
Passenger Outer Tie Rod end replaced at 101,327
Alignment at 101,327
Exterior: Brilliant Black Paint
Just resprayed the grille trim black a few days ago but can get back to silver if you prefer.
Will come mounted on 18x9.5 et45 Rotiform IND-T wrapped in 225/40/18 Yokohama S-Drives. Tires and Wheels are brand new Not even 5,000 miles on them. R/R wheel has slight curb rash.
Windows have 20% Tint all around.
Interior: Black Leather
Heated Seats.
Vent Pod Boost Gauge
RNS-E Head Unit. Has the the Nav CD and GPS antenna , just not installed.
New Headlight Switch.
The Whole Vehicle was Just Fully Detailed Inside and Out and is ready for a new owner!
All Items replaced were replaced with nothing but OEM product.
All inquiries please feel free to Call/Text at (732)-778-11294 or Email.
TONS OF FREE EXTRAS!!!
To go with the car I have everything I have collected for it over the years this includes:
-Original 17x7.5 spoke wheels. (could use tires)
-17x8 USP reps on Blizzak Tires for winter wheels.
-Brand New Forge Turbo Inlet Hose
-Brand New Tie Rod ends.
-OEM Euro Trunk Re-psrayed and Color-matched with OEM spoiler to go with it.
-Audi Symphony Had Unit and a Symphony II Head Unit
-Original suspension and Coilover set from before air.
-5x112 to 5x120 BMW adapter to run BMW wheels.
-Probably a few other things Im forgetting I have to go through the boxes of parts in my attic.
