Hey Everybody,
First off, thanks for all the help this board has already provided! (A/C problems in Georgia in mid-summer!!) Now I'm tackling a few other things and have a few more questions:
Here's what I am working on: a 2003 A4 B6 (AMB motor) manual trans, FWD
Coolant has been leaking from back by the flange, so you know what that means...! I changed the flange and also the hose coming off the bottom of the flange with the plastic “click” connector. I'm glad I ordered that hose too, because the PLASTIC FITTING was the only thing leaking. I found that the flange that I had put in, about 3 years and 40,000 miles ago was actually doing just fine.
**** ALSO, though, I had noticed that the valve cover gasket had started leaking quite a bit, seemingly from more than one place. I've heard that a common cause is that the block breather system is messed up, leading to pressurization of the case, and thus oil leaks.
So before I did the flange, I started by changing the valve cover gasket. I wasn't able to get under the cam chain tensioner to change that small seal there, but it doesn't appear to be leaking from there anyway, so I left that part alone. That seemed to go fine, AFAIK.
I also ordered a few new parts, in hopes that I might avoid any more possible crankcase back pressure (and then oil leak) problems. I'm replacing the breather valve, the suction jet pump and the pressure relief valve (black "pancake" valve?). So if I make sure that those parts are all working and hooked back up correctly, I SHOULDN'T have any more breather problems out of the motor, right??? ( I might also order a bunch more viton check valves and replace all of those too...) Does this sound about right? I read about deleting some stuff out of the system, but at this point, it seems probably simpler to keep it stock.
TWO MORE QUESTIONS:
1) When putting everything back together, I found a loose hose end. It is a pretty thin vacuum line that I think is attached down by the right motor mount, maybe to one of the intercooler duct tubes(?) I think that it was routed up and around the front of the motor. The upper timing belt cover has clips for two hoses – one fat and one skinny, and I think this was the skinny one. Where should the other end of that hose go? I've been digging through diagrams and haven't figured this one out yet.
2) In the past 6 months or so, I have found that the car is hard to shift into a gear (first or reverse) when the motor is cold. It gets easier as I start driving. I checked the hydraulic fluid, and bled the clutch slave cylinder, but that didn't change anything. I'm positive that the transmission could use new fluid, and have been reading posts about the types, etc. I'm leaning towards the Redline MT-85 (75W85 GL4). It seems reasonably priced, too. When I drain the old stuff, I am going to see how it looks, and measure the quantity too. Hopefully some new trans oil will help with this. Any suggestions on that? Also, a transmission that is just hard to put into gear when the motor is cold is probably NOT an indication of a clutch problem, is it? Everything else seems fine with the gearbox from what I can tell.
I'm all ears, guys. What can you tell me?
Thanks!!
