So my 1.8t will overheat because my coolant fan doesn't run. I found the 60amp fuse below the dash had popped, replaced it but fans still didn't operate. I cut and tested each individual fan which runs when directly connected to the battery but the resistance measured on each fan is only .7 and .8 ohms each which I found odd. I pulled another fan control unit from a junker today and it just popped my 60amp fuse again. Could be I just got another bad one, I've read these units failing is a common b6 issue (btw the one on my 03 is the 600w 8E0959501AG one) so I've just ordered a no name replacement from amazon prime.
I was wondering what everyone else's experiences with failing control units. If yours died on you did it take your 60amp fuse with it like mine did? Has anyone measured the resistance of their fans and is that low value to be expected? 13.5v / .7ohms = ~20a so even while it is a low resistance this alone shouldn't cause a 60 amp fuse to break. I've recently done my timing belt and removed the front end and while I did this I removed my inoperable A/C compressor. Not sure if my A/C compressor left disconnected would cause this but I mention it anyway because I know one fan operates to lower coolant temperatures and the other fan is operated to assist in climate control. I should also mention I have test the operation of the fan relay, I get ~12v at the accessory wire going to the fcu (from what I understand the 4 wires going to the fcu are power/ground/ecu/acc., power and ground are constant however fused 60a, acc is on a relay and fused in the driver side fusebox and the last wire is a pwm signal from the ecu)
