Results 1 to 8 of 8
Thread: Help!!!
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Help!!!
    My buddy's 2000 A4 1.8t Broke down. Don't know what it is.
    Symptoms:
    Limp mode
    No throttle response
    And engine noise. No oil light.
    Thanks for any help!
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Check oil level. Check codes. Report back.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Apr 26 2015
    AK
    Put an oil soaked rag into the fuel tank leaving some exposed and light it on fire. That should fix it.
    Seriously though. Is it still running at all? Will it restart after it has been turned off? Flashing CEL or it just won't come out of limp mode?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Jan 18 2016
    PA
    No check engine light. It restarted once and there was no throttle response now it won't start
    Apr 26 2015
    AK
    Hmm. Stupid question but does it have gas in it? Can you hear the fuel pump buzzing when you turn the key to the "on" position. If you're somewhere that you have some tools pull a spark plug and check for spark.
    Jan 18 2016
    PA
    Trying to figure this out still. The car started. No lights. Ran fine my buddy made it home from work(not far 2mi if that). He let it sit at home and took the truck to work. This morning he took it to work and hasn't had a problem since. Anybody have any ideas? Or should we just leave it for now?
    Jan 18 2016
    PA
    Quote Originally Posted by ccplus5_AK View Post
    Car had about half a tank. And the plugs/coils where good.
    Active Member Two Rings RingLeader02's Avatar
    Sep 21 2016
    87 fc rx7, 99 dsm gsx, 91 subi impreza, 81 maxim 650
    Lancaster, PA
    Quote Originally Posted by MarcRogers View Post
    Symptoms:
    Limp mode
    What's the noise?
    Sent from my 0PM92 using Audizine mobile app
    Insta: killcharmeloni
