    Apr 15 2014
    Ottawa/Gatineau Canada
    where is this abs module located?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Green arrow!
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Apr 15 2014
    Quote Originally Posted by PreciseD View Post
    Green arrow!
    The black plastic piece to the right of the green arrow?
    Established Member Two Rings xetura's Avatar
    Feb 17 2012
    2002 B6 Avant 1.8t 5spd, 1980 ABA Scirocco, 1978 Scirocco(resto project)
    Portland, Oregon
    Quote Originally Posted by Luxus Panzer View Post
    Yes. It makes it easier to remove if you undo the black retaining bracket, but it's still a pain. It has torx bit screws, can't remember the size.
    Aug 29 2014
    savannah
    I'd wager on them being t25, here is a video of the removal process that seems to be the easiest, its for a b5, but the process should be similar to our b6's. The modules pcb in in the black plastic housing and the abs pump that mates up the solenoids in the metal half. I'm actually sending mine off for repair to module master in two weeks.
