Results 1 to 10 of 10
    Junior Member Two Rings
    Mar 23 2016
    Is there a correct position for the diverter valves ?
    Hi there gang, just finished the 2.0t coil conversion and the tunable Forge diverter valves. I do have a question about the position of the dvs. I always thought this 2.7t is a symmetrical engine, and yet, the stock diverter valves are one in vertical position, the other horizontal. I did install the Forge valves the same way, but I keep wondering, the air flow should go the same way on both sides of the engine, why are the valves positioned the way they are ? Isn't the pressure supposed to hit the bottom of the piston where the spring is at ? Looking at pictures online didn't help much, saw all kinds of setups, with both valves vertical, both horizontal. From some videos I saw, there's a hissing sound associated with the new valves, my car has none, I did install the 23psi spring since I have the APR tune. Bottom line; is there a correct position for the dvs? And what would happen if they are in the wrong position ? My car is a 00 2.7 6 sp
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    I don't think you want a 23 psi spring in there
    Sent from my SM-G930T using Tapatalk
    Mar 23 2016
    Quote Originally Posted by Royal769sr View Post
    That's what ECS tuning recommended. Green spring for stock, yellow (up to 23) for mild tune, blue and red for highly tuned cars
    May 22 2013
    Las Vegas, NV
    Hmm. Weird. I would go with what they say but I thought you want to have the lightest spring possible. Even though that makes little sense when asking why they have different spring choices. Who knows. Maybe that's what my issue was this whole time lol
    Mar 23 2016
    If you have several springs, did you try replacing and see what happens ? Actually what is your issue ?
    Mar 23 2016
    OK, so I got my answer from the local Audi dealership. Previous owner installed one of them valves the wrong way. The piston inside should be activated by the flow from the horizontal hose, while the vertical hose is for exhaust.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by GroupBquattro View Post
    could you post the picture, as a service to community, so we finally know how correctly installed DV's should look like?
    Dec 04 2012
    Arlington VA
    Thank you!
