Originally Posted by
relative4
Did a bit of research on error code 3, and I think my next step is to clear a jam. Before getting into this, I should find out my security code. Apparently that's not on the sticker in the spare tire compartment; what is the current best way to get it without paying the dealer? Can I get it via VAG-COM?
Call Audi of America's support line. They should give it to you within 3 days. My code was in the stereo manual, though, so check there as well.
Having said all that you *should* be able to just disconnect it and reconnect it without needing the code. The only times I needed my code for my Symphony 2 or 2+ was when I would swap it to a different car.
Also, Nollywood, here in th US the base stereo was the Double Din Symphony 2 with the in dash 6-disc changer. We only had a glovebox CD changer with the RNS-E units.
