Results 1 to 6 of 6
    Oct 27 2015
    Phila
    VCDS won't connect to engine controller/module
    Hi everyone, is there a reason why VCDS won't connect to my engine controller but will connect to all of the other modules?
    It just seems so random that when i try to run the engine diagnostic the controller cannot be found..
    Any help would be appreciated.
    Veteran Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Which engine controller are you trying to access?
    My respray thread
    Oct 27 2015
    Phila
    I'm just trying to check codes/pending engine codes. Not sure what module that exactly is...
    Oct 24 2015
    Perth, WA
    Ok, so you have gone into options and made sure you have that all working?
    My respray thread
    Oct 27 2015
    Phila
    Everything else is working. I can connect to all the other modules besides the engine module.
    Also, I was running the auto scan with the both abs connectors under the hood and it completely drained my battery. The interior lights worked but the alarm chime, my key fob and the headlights would not work. VCDS was still.able to auto scan that car multiple times after it died with no mention of the car not being able to start.
    Oct 24 2015
    Perth, WA
    Charge your battery, and keep it charging while you scan it. A drop in voltage will cause all kinds of communications issues. Also there are various engine modules, on my car there are several and only the common area one works.
    My respray thread
