Results 1 to 8 of 8
    Sep 16 2015
    California
    Squeaky windshield
    Hi all,
    My A4 B7 3.2 six speed has an issue. On cold mornings, my windshield makes a squeaky noise as I drive over bumps. As a daily driver in San Francisco, you can only imagine how annoying my problem can be. I'm convinced that the clip that holds the VIN number on the driver side of the windshield is lose or needs some reinforcement of some sorts. I believe removing the dashboard would be helpful to fix this. However, there is no DIY write-up on how to remove the whole dash. Can anyone share a link or shred some light on how to do this?
    Thanks in advance!
    Sent from my Nexus 6P using Audizine mobile app
    Dec 23 2011
    Steps include:
    Remove drivers and passengers front airbags
    Remove steering wheel
    Lower the steering column
    Remove instrument cluster
    Remove radio
    Remove center console
    Remove glove box
    Lift dashboard out from the car
    If you still want to do it PM me and I can send you the Bentley instructions. It's more time consuming then it is difficult
    Feb 24 2004
    Minneapolis
    Had that on one of my B5's. There are defroster vents on the leading edge of the dash cover. They butt right up to the glass. On mine, I found that if I pushed on the dash cover in the right spot right by the windshield, squeak disappeared. So I bought a piece of black felt, cut a small piece, pushed down on the dash cover as I slid the felt in there, then let up on the dash cover. Never heard the squeak again.
    I'm not saying that's your problem, but I'd push down on that dash cover by the windshield before I did a dashboard R & R just to chase a squeak.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Sep 16 2015
    California
    Quote Originally Posted by p0isin View Post
    Steps include:
    Remove radio
    Remove glove box
    If you could share those instructions, that would be greatly appreciated! Thank you.
    Sep 16 2015
    California
    Quote Originally Posted by mtroxel View Post
    I'll give that a try! Thank you!
    Senior Member Two Rings Danne_gg's Avatar
    Oct 17 2009
    Touareg TDI 2012, Lupo GTi track car,Audi A1 TDI, Arctic Panthera 550, Coronet 24 weekender(boat)
    Stockholm, Sweden
    Had this issue on my B7 after windscreen replacement.
    Just had slim tool and managed to grab the vin numberplate and put it in place.
    Sep 16 2015
    California
    Quote Originally Posted by Danne_gg View Post
    What kind of tool did you use?
    Sep 16 2015
    California
    Update. Ended up replacing the windshield. First the shop installed one and squeaky noise wasn't so bad but I told them that I wanted the noise to be done with. A week later they installed a new windshield and it went away!
    Keep you updated if it comes back.
