Hello,
I have a 2000 1.8T A4 Quattro, I am having various Issues and i need help. The engine was overfilled by like 4-5 quarts maybe even more......it was ran this way but not for to long of a distance. I drained all of the oil and then refilled(to correct level) with brand new oil. On my test drive the low oil pressure indicator came on and the car shut down. Next I changed the oil filter, and oil pressure switch/sensor (Using Info from a thread search here). The low oil pressure indicator came on after the next test drive, then car stalled/died. I towed back home again. There is also white smoke sometimes at idle, but there was no other fluids in my oil after both times i drained it......could the head gasket still be blown and would my next step be changing the Oil Pump and pick up tube? PLEASE HELP!!
